Old 10-17-2010, 04:08 PM   #15
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
Dh is out in the stream right now. He is in the bathroom cleaning out old caulk/bleach water the creases/recaulking right now. He gonna smell real pretty when he comes inside!
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
Old 11-16-2010, 06:26 PM   #16
x
XXXX , XXXX
I just discovered something weird today. I was using a heat gun inside the trailer to soften up some vulkem to remove it. The eau de Airstream was very apparent while heating the vulkem. Either the vulkem has absorbed the odors or it is the source of the odor. Any comments regarding this would be greatly appreciated.
wasagachris is offline   Reply With Quote
Old 11-16-2010, 07:18 PM   #17
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Ours already had the fusty musty smell before Shawn resealed it...but that doesn't mean anything.
Nicki
TAC OK-42
Old 11-17-2010, 07:19 AM   #18
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
like you that old musty smell drives me crazy! Here's a real simple trick I "discovered" when a mouse came into our basement to die. We couldn't find it anywhere. So, out of frustration I put 2 or 3 trays of bleach in the room. I used disposable plastic sandwich size containers & put about half an inch of Clorox in the bottom. The smell was mostly gone in 2 days, & totally gone by the time the bleach evaporated.
When we brought our MH home in May, I used this meathod again. This time for musty smells & moth ball overload. Don't ask me how it works, but it distroys bad odors. The air doesn't smell like bleach either, just smells clean.
Schools Out is offline   Reply With Quote
Old 11-17-2010, 04:30 PM   #19
Splitrock's Avatar
Sioux Falls , South Dakota
I found this. I'm not sure what it means.
ozone_gen_fact_sheet-a.pdf
Gary
Old 11-17-2010, 06:25 PM   #20
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
There is a product you can buy at home depot by all the cleaning products called "odoban". It has succeded where other products have failed at removing odors like cigarrette smoke. That being said, it won't crawl inbetween walls.
ddstech is offline   Reply With Quote
Old 11-17-2010, 07:14 PM   #21
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
You're absolutely sure it's the Airstream and not what you are wearing?
Vaughan
Old 11-17-2010, 07:27 PM   #22
x
XXXX , XXXX
Evertone is posting about how to get rid of the smell. What I am wondering is does the vulkem create the odor or does it absorb the odor. I recently had a 75 Sovereign and it smelled exactly the same as my excella. Is the vulkem the commonality?
Vaughan Funny LOL. Are you sure that's not a sick sense rather thatn a sixth sense. LMAO
Old 11-17-2010, 07:37 PM   #23
1983 34' Excella
1967 24' Tradewind
Images: 32
Actually, I'm pretty certain that it is.
I suspect that the solvents in the vulkem as well as other adhesives used in construction all contribute to the smell.
A shoe repairman once told me that nearly everyone who came into his shop remarked how much they liked the smell of leather. He said that it was actually the glue and dye that they smelled.
Sort of like "new car smell."
Vaughan
Old 11-17-2010, 07:49 PM   #24
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Oh the odor. My wife is obsessed with getting rid of "That smell"! Abby just plain stinks! She needs lots of cleaning, scrubbing and disinfecting! Being parked for years in the Texas sun with the windows closed has not helped the "fresh" factor.
Good luck removing the smell!
Lance
Top is offline   Reply With Quote
Old 11-17-2010, 08:26 PM   #25
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
The bleach idea might be good for after christmas when she's driveway docked for the winter......
Nicki
TAC OK-42
Old 11-17-2010, 08:31 PM   #26
Central , Mississippi
We have had pretty good results with multi frontal efforts...
Get rid of the carpet...
Clean or replace all of the soft items...
Scrub all of the hard stuff...
Vacuum every inch to remove loose stuff...
Clean the inside of the AC...
Install an automatic Fantastic Fan...
AND...
run an ion machine when it's parked...
Even then the sole remaining 1-2 molecules will zap ya' nose from time to time...
AND sometimes that won't work...
I stuck the ION machine inside nasty the '63 we just bought...
and the next morning the machine was laying in the drive with it's own cord wrapped around it's intake...an obvious suicide...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-17-2010, 09:20 PM   #27
79nTOW's Avatar
1979 29' Ambassador
Mobile , Alabama
Friends of ours had the same problem in their house when they would leave for months at a time ...a really stinky smell. They were told to buy plastic bins and put them in each room in their house and fill them with charcoal briquettes. It worked like a charm. They can be used like this indefinitely over and over or tossed into the grill for a cook out . Only two or three would be needed for an Airstream. When you load up for a trip simply put them in the garage or laundry room. This does work and is cost effective.
Predeta
79nTOW is offline   Reply With Quote
Old 07-08-2011, 11:09 AM   #28
1966 30' Sovereign
1963 22' Safari
orlando , Florida
I dredged up this older thread after a considerable rain here in Orlando.The '66 Sovereign has always had a slight musty smell which intensifies after a good rain.I'm trying a simple fix.Open the closets and cabinets and leave them open.So simple,perhaps too simple but worth a try.
richie rich is offline   Reply With Quote
musty odor Elaine and Bohdan Dehumidifiers & Ozone Generators 20 12-08-2015 12:18 AM
That Smell! I Know What It Is Now! whitefawn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 03-09-2010 02:48 PM
Smell!!!! jim8860 General Motorhome Topics 5 09-07-2005 06:59 PM
Smell garry General Interior Topics 8 05-09-2005 07:31 PM
What do you smell? 87MH Off Topic Forum 27 07-24-2004 06:51 AM
