Old 04-07-2009, 05:46 PM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Ok I did something wrong with Plastic repair?
Well I had read that you can use Acetone and ABS for ABS repairs. Well I got hold of a sheet of molded ABS plastic and got some acetone from home depot . I then proceeded to shave off some ABS plastic into shavings and add them to 3 ounces if Acetone to my surprise it did dissolve the ABS a bit but
it ended up the consistency or play doo and would not desolve any more,Well while cleaning the area with ABS cleaner I noticed it was desolving the plastic as it cleaned so i mixed some ABS shaving's and believe it or not i got a good stable Plastic repair . Ill post pictures later.
ole
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 04-08-2009, 02:49 PM   #2
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
MEK (Methyl Ethyl Ketone) works much better then Acetone.
I cut up 1/4" X 1/2" chunks of ABS and fill a pill bottle about half full with ABS pieces and pour in enough MEK to cover the ABS and let it soak for a few days, stir it up occasionally. After the ABS has melted leave the container open and let the MEK evaporate off until you have the consistency you want or add MEK to thin it up.
I have been using this to fill fill hole and repair cracks, for cracks I drill a hole at the end of the crack to stop it from progressing and dig out the crack on both sides and fill it with my MEK concoction. Takes two or three applications as it shrinks when it dries and you can shape it with a razor blade the next day as it is still fairly soft, it has been 40 degrees around here and it take about 5 to 7 day to complete dry.
I discovered by accident:
I was making up a batch of the MEK, ABS concoction and mistakenly used Xylol instead of MEK and the next day I discovered the ABS chunks were clean soft and pliable but had not melted at all.
A few weeks later I was working on my A/C shroud and where it attaches around the fan it was brittle and dis formed, I could here it cracking while I tried to screw it down. Remembering my Xylol, ABS mistake from earlier so I soaked a rag in Xylol and draped it over the dis formed area with some Saran wrap over it to keep it from evaporating. I keep the rag wet with Xylol for abut 30 hours, after this time I was able to clamp and reform the ABS where needed, I left the clamps on for two days. It has been a week sense I did that, I am going to let it dry another week and if it still looks good I will do three more areas that need attending to.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 04-08-2009, 09:11 PM   #3
1977 31' Sovereign
Images: 33
Ok now i know why the ABS cleaner was working it has MEK in it ok next question where do I get just MEK? i used the ABS cleaner and it did great but I think i need to change the mix and like you said leave it for a few days .
K/N Cool intake air
Duel power exhaust
Old 04-08-2009, 09:19 PM   #4
1977 31' Sovereign
Images: 33
Hey check out my pics of Plastic repair.
Please forgive the slop of it this is my first time and i did it on a non showing side.
Four things learned :
1) Off the bat do not use Aluiminum screen as support mechanism it wont work.
2) Use fiberglass cloth I am willing to bet it will soak up plastic and support well when dry.
3) Use MEK instead of Acetone MUCH MUCH better results .
4) Let mixure set for a day to totaly disolve ABS pieces.
My Pictures
K/N Cool intake air
Duel power exhaust
Old 04-08-2009, 10:49 PM   #5
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Home Depot has MEK in pint cans
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 04-09-2009, 11:15 AM   #6
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
MEK can be had from Home Depot, Lowes, Menards, most hardware stores I would assume.
Bruce,
Old 04-09-2009, 01:42 PM   #7
VIKING's Avatar
Boulder Creek , California
Use extreme caution when playing with MEK like this. It is very flammable and it's attracted to your liver from what I've been told. Use heavy rubber gloves and eye protection, and lots of fresh air please.
Rich
VIKING is offline   Reply With Quote
Old 04-09-2009, 03:30 PM   #8
1963 24' Tradewind
San Diego , California
Most any place that sells paint sell MEK
Sixty3TW4US is offline   Reply With Quote
Old 04-11-2009, 04:07 AM   #9
1977 31' Sovereign
Images: 33
Just a update on first attemps at repair
Just so you all know this is a learning experience so I am in the learning stages of the game. Well like I said one thing is clear do not use metal screen as patch or support it will react to the chemicals and start to deform as you add plastic compound. Another thing do not use to much plastic compound it will start to disolve or soften the plastic around it(in other word's I will have to repair the repair when it hardens) Oh and I made a mess trying to get the feel for the plastic compound. Well I have learned some things one is fiberglass adhesive patch tape, That and PVC/ABS cement works great I repaired the bathroom sink basin with that and it made the edges nice and strong and stopped the cracks along the rivit hole's. Well good news is I am getting better at it each time I do it. One repair where I used the plastic compound was the drain hole in the tub I glued a piece of ABS from underneath and built up the edge's then used the compound and filled in the space from inside the tub . I will give that a few days to dry and redrill drain hole. I also started in on the vista window's they have moister in between panes and the caulking was all deformed so I used a glass cutting blade on my rotor tool and proceed to remove first pain along the way it started to crack which is what I wanted it to do and I removed the first pane removed the caulking and replaced with vulkem . I am going to let it dry and clean up left overs with blade. have pics ill post them tonight)
K/N Cool intake air
Duel power exhaust
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 3 11-12-2013 09:03 PM
Cracks in Plastic...How do you repair? tkendall General Interior Topics 6 02-05-2008 08:32 AM
Plastic resin Code '1' PET tank repair fotochop Waste Systems, Tanks & Totes 11 01-28-2008 07:50 PM
Plastic water tank repair/replacement Globestream Fresh Water Systems 5 09-10-2004 09:34 AM
Something wrong with.. 53flyingcloud Our Community 7 11-24-2003 02:30 PM
