Old 08-11-2013, 08:45 PM   #1
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
New Tile Backsplash
We didn't like the wallpaper boarder in the Classic. We opted for this solution.
I'm happy with it.
Name:	tile small.jpg
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 08-11-2013, 08:57 PM   #2
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Is that five big sections of tile made to look a plethora of small random tiles?
ggoat!!! is offline   Reply With Quote
Old 08-11-2013, 10:08 PM   #3
2004 28' Classic
austin , Texas
That looks great. Is it the peel and stick type of glass mosaic? Did you use grout?
Ntex is offline   Reply With Quote
Old 08-11-2013, 10:14 PM   #4
TAC-TN3
transplant's Avatar
2005 31' Classic
near nashville , Tennessee
hi dan b i agree the wall covering is not good. we replaced ours with a wallpaper border that i saved from our old house. it fit perfectly. yours looks like glass, is it?
we also replaced the faucet with a single lever one. it looks cool
little things do make a difference.
keep posting pix
transplant is offline   Reply With Quote
Old 08-12-2013, 06:15 AM   #5
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
These are called "smart tiles" available at Lowe's. They come in 12x12 sheets that interlock. The "tiles" have a true 3-dimensional shape that gives realistic shadows and reflections.
They are "peel and stick" and can be cut with scissors. The backing material serves as the grout. The interlock pattern is fairly good.
The sticky felt OK. I'm more concerned about how they do over the winter.
Best part is they are very light.
DanB
www.campnova.com
Old 08-12-2013, 06:33 AM   #6
Lily&Me's Avatar
Normal , Illinois
Lovely!
Maggie
Lily&Me is online now   Reply With Quote
Old 08-12-2013, 10:38 AM   #7
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
They look very nice! I always hated the wallpaper border in our Safari.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-12-2013, 12:54 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Looks good.
I hate that wallpaper, too. Mine is already peeling because I got it wet brushing my teeth.
I have thought about aluminum skin like the kitchen throughout the trailer.
I don't like than sob looking tan-ish wallpaper on plywood on the bedroom and bathroom partition walls. This should have been some more hickory wood. Stained and polyurethaned plywood would look better to me.
I don't like the mouse fur walls or padded vinyl ceilings, either. Those surfaces should have been silver aluminum instead.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-12-2013, 04:43 PM   #9
2004 28' Classic
austin , Texas
We used a peel and stick product from Lowes too, but ours are silvery brushed aluminum looking. My husband used a power saw to cut them. We also replaced the mirrors in the overhead lockers in our 2004 Classic. I think it modernized it a bit. Now trying to decide whether to put them behind the stove and sink too.
ID:	193044   Click image for larger version
Old 08-12-2013, 04:57 PM   #10
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Those look great in both spots. I pinned some just like that on pinterest as a potential use in our trailer. Are you just relying on the peel stick to hold it or did you supplement with any adhesive?
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-12-2013, 05:53 PM   #11
2004 28' Classic
austin , Texas
Just the peel and stick. It seemed up to the task completely. One thing I read was you only needed extra adhesive if you had to cut it in a way that left really small pieces along a side. Then you might need to add some in that spot. My husband used a power mitre saw to cut them to exactly fit.
Old 08-12-2013, 06:56 PM   #12
1999 30' Excella 1000
Griffin , Georgia
Did you remove the old wallpaper, or place the tile right over it? It looks great, and I am going to try it also.
Bassrats2 is offline   Reply With Quote
Old 08-12-2013, 07:45 PM   #13
2004 28' Classic
austin , Texas
I pulled off the wallpaper border, which was easy and left the wallpaper underneath intact. I stuck the tiles on top of the wallpaper. Be aware that where we had to cut the little metal mosaics pieces, the edges were a bit rough. I hid those up high under the mirror. I was able to go side to side with no cutting. I googled the product to get some tips on cutting and installation. Where one mat of tiles buts up against another, you need to try to get them really close together or the seam will be obvious. And they really are sticky so be careful....once up they are hard to remove. I did succeed in removing one section however and starting over with a new set of tiles on that area.
Old 08-12-2013, 07:45 PM   #14
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
The old wallpaper was adhered very well. Plus, the tile are very light, so I just went right over the top.
DanB
www.campnova.com
