Old 01-01-2004, 06:40 PM   #1
New Carpet for Walls
I wish to line my walls with carpet, particularly around the rear bedroom, for both aesthetic and insulation value.
Has anyone done this, or know of a source for light weight carpeting?
One of the problems I envision is getting the fabric to conform to the compound curves in the bottom rear without having to cut triangular shapes out of the fabric to get a proper fit.
Dick
Navigator is offline   Reply With Quote
Old 01-01-2004, 06:49 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Entirely possible..
Dick
If you check the newer A/S, you'll find that the factory uses a carpet like material on the walls and ceiling..
You might give them (factory) a call to find out the source.
It's possible that it's listed on a thread on here somewhere as well..Good luck~!~
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 01-01-2004, 06:58 PM   #3
We had a piece of fabric-covered cardboard along the side of the bed that had become stained badly enough over the years that we replaced it with carpet. Our choice was a remnant of very, very plush neutral colored carpet used by a limosine builder. To provide a finished edge we had it bound on all sides.
As you have noted, the problem is the compound curves. Getting our rather heavy carpet cut to fit was somewhat tedius and took multiple trial fittings. The lighter weight you can get, the easier it wil be.
In hindsight, we would have been better off working from a paper pattern.
There are also wall cover fabrics that are almost light weight carpet. The only difference really is the lack of backing. This would be easier to work with. It is sometimes sold by carpet stores as well as wall covering stores.
Mark
Old 01-01-2004, 10:01 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Re: Entirely possible..
Originally posted by 53FlyingCloud
Dick
ciao
You can buy the material from Airstream (take a look at the parts books for the current models on the Airstreeam web site) for part number. The same material was used in my International and in the bottom half of the walls in my Classic. It goes up with contact cement.
The material used in the current Airstreams fits compound curves a lot better because it has a lot more give than carpeting. It is designed to stretch easily.
John W. Irwin
WBCCI #9632
Old 01-02-2004, 05:45 AM   #5
LOST , Hawaii
Check out Ozite by Foss. It is a non woven fabric that is used for commercial wall coverings, good for noise reduction and probably better than aluminum for insulation.
John
74Argosy24MH is offline   Reply With Quote
