Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 03-29-2008, 04:44 PM
Dan Clayton
Dan Clayton's Avatar
Profile:  1956 22' Flying Cloud
West Linn, Oregon
Question Reflectix Foil Insulation / Installation
Has anyone installed foil backed insulation such as Reflectix? Did you attach to the inside of the outside wall first, or did you put it over the top of the fiberglass insulation, so it's touching the backside of the inside wall. I want to attach to the backside of the outside metal on both the front and rear crown. Then I was going to put fiberglass insulation over the top of that, which then would be covered by the inside metal caps. I was doing it this way to make a barrier in case I ever had a leak in the crown the water would run between the foil insulation and the metal caps down to the lower body, rather then get the fiberglass insulation all wet. The only downside I can see is that the heat from the panel will transfer thru the foil insulation, since there is no air space between the foil insulation and the metal cap.
Get rid of these ads... register today, it's FREE
Old 03-29-2008, 05:10 PM
markdoane
Profile:  , Minnesota
There are several examples if you search the archives. Most users are gluing spacers in so that the bubblewrap is suspended halfway between the walls.
A search on 'reflectix' returns 36 threads.
There's a fine line between a hobby and a mental illness.
Old 03-29-2008, 10:23 PM
malconium
Profile:  1973 31' Sovereign
Portland, Oregon
Installation details...
I give some detailed instructions about how I installed reflective foil insulation in the following thread:
Foil insulation - observations, tips and tricks
I would also be happy to try to answer any questions that you might have about the process.
Malcolm
vB code is On
Pingbacks are On
Foil insulation - observations, tips and tricks malconium General Interior Topics 50 08-20-2007 07:27 PM
Anyone used Foil Bubble Insulation???? soldiermedic Upholstery, Blinds, Walls & Interior Finishes 28 11-13-2006 11:39 PM
Insulation C Johnson General Interior Topics 22 04-30-2005 02:12 PM
Foil Bubble Insulation Methods mbatm01 General Interior Topics 50 04-07-2005 02:48 PM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
