Old 05-28-2004, 06:24 PM   #1
1975 29' Ambassador
denman is , b.c.
Question Need info. on 1976 interior front panel of Ambassador.
We have a large crack in the interior curved front cieling panel. Airstream says the 1976 is not in stock anymore. Would there be much difference between the 76 to the 77 ? Can't seem to get an answer from them.
kooshka is offline   Reply With Quote
Old 05-28-2004, 10:29 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Archives
check teh Vintage Airstream photo Archives. They have pretty much all the popular trailers with interior shots.
http://www.vintageairstream.com/archives/index.html
Just pick your model, and then the same one for another year, and perhaps you can see the difference.
good Luck!
Uwe
www.area63productions.com
Old 06-05-2004, 06:20 AM   #3
You are not the only one
I, too, have a cracked curved front section.
I was trying to determine how or why that happened before I attempted to repair it.
Vibration, shrinkage?
Must be a common problem.
Stagehand is offline   Reply With Quote
Old 06-05-2004, 07:03 AM   #4
It is a common problem. Inland RV had a few end caps, but I don't know for what years.
They are either fiberglass or abs plastic, depending upon the year. Either way, they can be repaired.
Mark
Old 06-05-2004, 09:47 AM   #5
1975 29' Ambassador
Reno , Nevada
From what I hear, the first thing you should do is to drill a small hole at the end of the crack to stop its spreading.
Old 06-06-2004, 08:51 PM   #6
1976 31' Sovereign
I have a 1976 31' sovereign and just noticed I have the same crack. I also noticed there is a bit of water just under the back window. Has anyone else noticed a leak and if so were you able to find out where the water is coming in.
Loretta
travel is offline   Reply With Quote
1976 Ambassador T&R 1974 - 1979 Ambassador 22 06-30-2015 08:03 AM
Attempting to access front eyebrow panel Don in E Texas General Interior Topics 4 04-14-2004 08:04 AM
Control panel wanted... Rick Electrical - Systems, Generators, Batteries & Solar 0 09-03-2003 03:40 PM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
