Old 06-08-2013, 09:32 AM   #1
mercury7's Avatar
1959 24' Tradewind
easley , South Carolina
Need immediate help.. Univolt
So I am at a stage replacing the univolt where I am about to disconnect the fuse board and connect up the intellipower.... Problem is identifying positive and negative plus a third thinner whitish wire going in to the back.. Only places for poditive and neg
mercury7 is offline   Reply With Quote
Old 06-08-2013, 12:43 PM   #2
1988 32' Excella
Robbinsville , New Jersey
This thread has a diagram that might help.
http://www.airforums.com/forums/f449...hot-49282.html
Old 06-08-2013, 12:50 PM   #3
mercury7's Avatar
1959 24' Tradewind
Thanks, now having trouble because apparently it takes a special Alan wrench to connect to intellipower.., j tried just touching the wires to the contacts but nothing..,, wonder if the unit might be defective.... Going to go buy some wrenches and check again
Old 06-08-2013, 05:32 PM   #4
mercury7's Avatar
1959 24' Tradewind
All is well ... Got it all working, any suggest on where to ground the intellipower?
Old 06-08-2013, 05:48 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Ground it to the frame for one spot. If a frame connection is not close by, look for the elevator bolts and drill a new hole close to one and use a self tapping screw to attach the wire. Also another ground to the inside aluminum skin couldn't hurt. You can never have too many ground wires.
ventport is offline   Reply With Quote
