Old 07-26-2004, 11:07 AM   #1
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Need help with mildew
Attached is a close-up photo of one of two oak "shelves" that are in the back of the Bambi II sofas. Each shelf has two brackets which are used to secure the back of the sofa in an upright position when it is set-up as a sofa. Both shelves are under a window which must have had some leakage in the past. The problem I'm having is removing what looks like mildew deep in the pores of the wood. I have tried various grits of sandpaper (starting under 100) to no avail. I was planning on restoring the finish with stain or Watco oil. Any ideas or pointers would be much appreciated.
Name:	Mildew wood example.jpg
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 07-26-2004, 11:12 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Bleach on a cloth mixed with water 50/50 will clear this up. We had the same trouble with window sills in our home in WI. The bleach will kill all the mold as well as return the wood to a like new color. If the wood is currently stained with a color you may lose that and have to re-stain.
Wet the cloth, and blot at the wood. Keep a bucket of clear water and a clean towel for rinsing. You may need to blot and let it sit for a while to work into the pores.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Milldew problem and more Ed & Nancy Our Community 1 12-30-2003 06:13 AM
MILDEW/solar ventilator Lexxy General Interior Topics 3 08-14-2003 09:26 AM
