Old 06-19-2006, 07:05 PM   #1
1967 26' Overlander
sebring , Florida
Need Help On Sofa/bed
I'm Restoring A 1967 Overlander I Have No Cushions For Measurements. I Need To No How Wide Is The Botton & Back Cushions And How Far Do They Pull Out.(front) There Is Also A Side Sofa Between The Kitchen And Bathroom And I Need To No The Same Measurements. Going To The Upholster Tomarrow. John
jjohnjr is offline   Reply With Quote
Old 06-19-2006, 07:17 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
John, unfortunately the storage lot where we keep our coach closes at 9 PM, so I can't go measure our cushions for you. However, maybe I can help you guess how big they need to be.
First, the easy part. Measure how long the cushions need to be by measuring the plywood base's length. Now you have that dimension, measure how wide the plywood base is, with it NOT extended. That will be the width of your bottom cushion. Next, extend the base out, and measure the difference from the retracted position. That will be the width of your side, or back, cushion.
Sorry I can't give exact figures, hopefully you will be able to do what is needed by following the above steps.
Old 06-19-2006, 07:37 PM   #3
1967 26' Overlander
sebring , Florida
Thank You Terry, If you have time to get measurements in a day or two that will help. I understand what you are saying. John
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Front Goucho-Bed JIMANDHELENE General Interior Topics 8 05-18-2002 01:10 PM
Interior help desired - We need more sleeping space Curtis-79MH General Interior Topics 3 03-19-2002 06:08 PM
