03-13-2011, 09:02 AM
Louisburg
, North Carolina
Need 12V Schematic for '77 Trade Wind
I have searched the forum for a 12V. Schematic for my 77 Trade Wind but can not find one. If anybody can help with this please let me know.
Thanks.
"Shiny Aluminum Bodies will always turn a REAL man on"
Don't Let the Grass Grow under your Rig!
2004 GMC2500 HD Duramax~ 1987 Avion 30 P
03-13-2011, 09:12 AM
Corona
Thanks.
That schematic is in the "service manuals" that are available.
What problem are you having with the electrical, 12 volts or 120 volts, and which circuit?
03-13-2011, 09:29 AM
1967 22' Safari
1960 Caravel
Edmonds
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
03-13-2011, 11:07 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
schematics
Here are the 12v schematics.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
03-13-2011, 11:17 AM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
These schematics from '75 are bit more detailed. If you want to be able to read the wire color codes, the attached file is a bit bigger, but right now I can't figure out to retain the full file size when it uploads. If you'd like the 600K version, send me a PM.
Zep
03-13-2011, 11:29 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Mainstream, if you want a digital copy of both the 1977 owner's and service manuals, I can burn you a CD and mail it to you. Send me a personal message if you want a copy.
Kevin
03-13-2011, 07:43 PM
Louisburg
, North Carolina
A previous owner has installed a new converter but did not connect it to the Amp. Meter and I want to do that plus just want to be sure of all of the wireing of the 12V fuse board.
03-13-2011, 10:25 PM
Corona
The amp meter circuit must be slightly modified in order to work with newer style converters.
Unfortunately, I have that information, but at work.
I will strive to post the instructions tomorrow.
03-14-2011, 08:14 AM
1973 23' Safari
1977 23' Safari
Palmer Lake
If you're needing a shunt, you can make a very good one, cheap, out of a short length of #10 copper wire.
Zep
03-14-2011, 09:42 AM
Corona
Sorry, I was mistaken.
The modification I was thinking about is for the power on light, and not the ammeter.
03-14-2011, 04:19 PM
Louisburg
, North Carolina
Andy,
I also need the power on light to work so that would be handy.
They installed a IOTA OLS 55/IQ4. They taped off one of the two red + wires comming from the new converter and just left it not connected to anything . Also the 5th fuse from the left on the fuse panel is no longer connected to anything.
If that makes any sense maybe you can tell me how to get the red power on light to work etc.
03-14-2011, 04:28 PM
1973 23' Safari
1977 23' Safari
Palmer Lake
...If that makes any sense maybe you can tell me how to get the red power on light to work etc.
The easiest and probably the best way to get the power on light to work is go to radio shack or the local surplus store and get a 12V DC power unit, the kind that's a lump with the 120V plug stickingo out of it. Plug it into the unused side of the 120V socket under the sink and use its output to light the light.
The new converters don't have an isolated 12V output to show that the converter is powered, so the whole 12V system is always hot from the battery. The dodad above is the easiest way to get isolated 12V.
Zep
