Old 03-15-2009, 08:20 AM   #21
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Let me add the aluminum trim would keep the insulation between the warp and the floor in place.
Removing asbestos tile is not to bad you may want to do a search on approved methods. If I remember correctly you have to be sure it doesn't become friable. This basically means keep it moist, I think custom solutions are made for this and wear protection especially a respirator. Double bag removed tiles and the debris must go to a designated land fill. If in doubt treat it as asbestos. Check you local area regulations.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-15-2009, 09:21 AM   #22
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jim,
You are correct, friable is the key word. Check out this site for some answers and explanations....
What is Friable Asbestos?
I think the mystery cubby hole is a smugglers hold.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-15-2009, 01:52 PM   #23
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by safari62 View Post
My 62' Ohio Safari original tiles were not asbestos type. I brought a section to a professional flooring person carefully wrapped in a plastic bag sure that he would confirm my worst fears. The toxic hazemat extraction of 45 year old tiles of death.
He said no they were not. I had stressed over this same thought for six months thinking this could be the biggest downside of restoration. So take a piece to someone that knows older products.
The only way to be sure that there is no asbestos contained in any product manufactured prior to the mid-70's is to have a sample tested at a lab that is certified to test for asbestos. Asbestos fibers are microscopic. No one can just look a sample and say for sure that there is no asbestos in the material.
Family of Disney Fanatics
WBCCI# 4821
Old 03-23-2009, 10:04 AM   #24
1954 22' Flying Cloud
2009 16' DWR
Cambridge , Ohio
Hi; FYI-I sent a sample of the 9" x 9" tile to a lab. The tile itself was not asbestos, but it turns out that the adhesive used to hold it down contained 1-3% asbestos! It was a much worse job than removing tile, as I had to get a solvent and apply it to the (dry & crumbly) adhesive left on the floor, then scrape it up when it got soft. I had to wear a respirator, eye protection, chemical resistant gloves, rubber boots, and a tyvek coverall. It took about six hours to scape up all the adhesive and wipe down the floor with mineral spirits, and I only was sworking with about 80 square feet. Ah, the joys of renovation. Marika
silverjunkie is offline   Reply With Quote
Old 03-29-2009, 08:44 AM   #25
2006 30' Safari
Orlando , Florida
You were wise to have the material tested. Asbestos is a spiral fiber. Because of its shape is made an excellent reinforcement for many materials including mastics. It would have a certain stretchability in the material making the mastic flexible and strong.
I renovated a house after a kitchen fire a few years ago that was built in the '50s. There was three layers of vinyl floor in the kitchen. The bottom layer of vinyl tile was held down with asbestos containing mastic. We had to use an asbestos removal company to remove the kitchen floor. A lot of work for a small amount of flooring.
WBCCI# 4821
1962, 1962 overlander
My New 1962 Overlander Project BarryIowa 1960 - 1964 Overlander 226 06-25-2009 07:30 PM
looking for other 1962 Overlander owners Frank's Trailer Works 1960 - 1964 Overlander 14 03-21-2009 05:44 PM
'68 Overlander Floor replacement HELP!! Aluminati Repairing/Replacing Floor &/or Frame 96 01-18-2008 11:24 PM
Flex in Floor - 71 Overlander Ganglin Repairing/Replacing Floor &/or Frame 10 09-26-2006 09:09 PM
1968 Overlander Rear Bathroom floor mharrison@ie Repairing/Replacing Floor &/or Frame 0 09-26-2006 02:41 PM
