Old 01-02-2012, 06:47 AM   #1
gainesville , Florida
My trailer smells like mothballs
hi, i'm new to rv'ing. i have a 2008 31 classic. ever since i bought it it had a strong smell like mothballs. i've tried everything to air it out and have had the trailer for months now. when its closed up it still gets pretty strong. when you open the cabinets the strength is strong. Could it be the glue they used to build and if so does everybody have this smell?
thanx, stuart
stuartkaye is offline   Reply With Quote
Old 01-02-2012, 07:10 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If it smells like mothballs, it's probably mothballs. It probably either smelled musty, or like dogs, and the PO added mothballs somewhere you haven't found them yet, or they've disolved into the carpet where they were. Try vacuuming everything in the trailer, even the curtains (gently). Put n open box of baking soda on the floor in a central location, and leave the trailer for a couple of days. Come back and check for the naptha smell then.
Old 01-02-2012, 07:13 AM   #3
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Did you buy it used? Maybe the PO used moth balls during storage? Here's a couple of links that may help.
http://www.ehow.com/how_4453525_get-...all-smell.html
http://www.imtek.biz/page/N/CTGY/sp-moth
Good luck but it sounds like charcoal, heat and a good airing out for a month is the only way to get rid of the smell.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 01-02-2012, 07:47 AM   #4
dznf0g's Avatar
Oswego , Illinois
I used mothballs in my old SOB. I couldn't smell them after a spring airing out....but my wife PROHIBITED them when we got the AS. Apparently she smelled them all year long.
Are you sure you're not smelling ammonia from a leaking fridge cooling unit?
-Rich-
Old 01-04-2012, 09:32 AM   #5
thank you for your help. weve tried baking soda and airing it out for days. yes it had a po and was sold at auction. also the smell really bothers my wife more than me and she is the one insisting its mothballs.
Is there a possibility that it could be construction glues or something like that? it always seems stronger if i have been gone a few days and the unit is closed up.
again thanks for the great response.
stuart
Old 01-04-2012, 10:00 AM   #6
dznf0g's Avatar
Oswego , Illinois
It should go away if it is aired out significantly on a repeated basis. Are you SURE there are not still actual mothballs hidden somewhere? I used to find the areas under cabinets, in floors, in storage compartments where likely entry point would be for mice and place them tucked away somewhat hidden. Look EVERYWHERE.
-Rich-
Old 01-04-2012, 10:08 AM   #7
2012 25' Flying Cloud
Eureka , California
stuart
My trailer is new. It came with a warning about the use of adhesives and bonding agents in the materials used for construction. I don't smell them, but many people are far, far more sensitive than me to such chemical odors.
Materials like MDF, which are common in RVs, have lots of chemical agents in them, like formaldehyde. There is an instrument that will actually measure the air for such chemicals. I would call your local Heath Department and see if you can bring the trailer to them and have them analyse the air. I'll bet they can. Good luck - I hope you get it sorted out!
redwoodguy is offline   Reply With Quote
Old 01-04-2012, 10:25 AM   #8
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
GI disturbances
GI eruptions will either eliminate the mothball odor, mask it, or make you wish you had it back. So chow down on what ever creates the biggest bang for your buck.
wmarsha is offline   Reply With Quote
Old 02-20-2012, 07:00 PM   #9
2004 16' International CCD
Orem , Utah
OO mothballs, looked at old 66 Porshe 912 the smell o the smell I had to pass.
starcraft is offline   Reply With Quote
Old 02-20-2012, 07:16 PM   #10
reinergirl's Avatar
Hollis , New Hampshire
As a 2008 I would assume that the glues/plastics have finished off gassing. If it truly is mothballs that can be tough. I have an old trunk that despite having sanded and resealed it, it STILL smells like mothballs.
I sent my son to college with something called an Bad Air Sponge , seems to work LOL Bad Air Sponge® - Bed Bath & Beyond
I'm guessing that the PO tossed some somewhere where you haven't found them yet, check any openings in the belly pan. Good luck! Like your wife I am extremely sensitive to smells. Mothballs are only slightly worse than skunks.
reinergirl is offline   Reply With Quote
Old 02-20-2012, 08:44 PM   #11
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
We bought our trailer used and the previous owner had moth balls in small plastic bins stuck in every nook and cranny, as well as several in the outside storage lockers back in the corners. Once we found them all a good airing out took the smell away. We also vac'ed the carpet after a liberal dose of powdered carpet cleaner, followed by a pass with a rug doctor carpet cleaner.
dirigible25 is offline   Reply With Quote
Old 02-20-2012, 10:11 PM   #12
Ottawa , ON
My wife said to try this: buy a couple of big boxes of dryer sheets, and leave them all over the entire trailer, in cabinets and lockers, under things, EVERYwhere.
Shut it up for a week or two, then let it air out. Those dryer sheets are potent!
Old 02-20-2012, 10:34 PM   #13
tpi
Trabuco Canyon , California
I can still smell the plastics and construction materials in my '05 at times, but it smells nothing like mothballs.
Like the other suggestions, I'd suggest looking around for a few tucked away in an out of the way place. Perhaps something like the water pump compartment, etc. there are a few pull off panels in mine.
tpi is offline   Reply With Quote
Old 02-20-2012, 10:34 PM   #14
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm not entirely sure they smell better than moth balls, though.
— David
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Termites in my Trailer acbolton Winterizing, Storage, Carports & Covers 4 06-09-2011 08:36 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
