Old 01-03-2011, 09:37 PM   #1
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
My insulation progress....The triple layer combo
After reading and reading with no real conclusion, I have decided to combine the two worlds of insulation together, creating a sort of super-insulation mutant. I will provide testing results soon. But so far, I am very satisfied.
I purchased prodex insulation which is a true joy to work with. It contours to the curves of the trailer very well. I used a light amount of glue (put out by sikka which I found at lowes), to stick the prodex to the aluminum inside the trailer. Then I followed that by 2" (which actually measures closer to 1.5") fiberglass insulation (the pink stuff). Then I followed that by another layer of prodex insulation. The fit of the total insulation is very good. It doesnt compress the fiberglass insulation very much which I know is a very big concern.
I realize this might be a little more (maybe a lot more) in cost, but I do hope to take the trailer during the summer months to some hot climates and having spent time in it during the summer here in sacramento, I want to do everything I can while I have it apart. And hey, its only money.
Thoughts anyone?
ddstech is offline   Reply With Quote
Old 01-03-2011, 11:02 PM   #2
1975 29' Ambassador
Reno , Nevada
What strikes me is that you are not using the reflective properties of the Prodex which are its major insulating value.
I also wonder about condensation. Where will it occur in that sandwich and where will it go.
For a one-shot, the money isn't that big a deal compared to everything else, I think.
Old 01-04-2011, 12:28 AM   #3
ddstech's Avatar
Folsom , California
If I am not mistaken the outer layers would be reflecting both ways. The layer closest to the inside wall would be reflecting the outside temps and the layer on the outside would be reflecting the inside temp. As for condensation, I have no idea where that is going to go.
Old 01-04-2011, 07:59 AM   #4
x
XXXX , XXXX
Produx works best if an air space is maintained between the outer shell and the insulation and another air space between the insulation and the inner walls. By gluing your insulation against the outer shell you do not have that air space and will not get the desired R value.
The fiberglass insulation will absorb water from any leaks that may occur and it will also absorb the condensation and the produx will help to trap that moisture in. You might want to rethink your plan IMO.
Chris.
wasagachris is offline   Reply With Quote
Old 01-04-2011, 08:08 AM   #5
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I'm in the process of doing mine with Prodex right now. I agree "the stuff is a joy to work with". I agree with Chris though, I went with Prodex for it's effectiveness, not so cozy as a home for vermin, and it would not absorb water. I am doing two layers with an airspace between the shell, the layers and the inside skin.
SilverHoot is offline   Reply With Quote
Old 01-04-2011, 09:51 AM   #6
ddstech's Avatar
Folsom , California
silverhoot, how are you going to create the airspace inbetween? are you just stuffing the two layers in there? Or are you putting some sort of spacers? I could glue strips of prodex to the surface then glue the sheets to that which would create air pockets right?
I guess my thinking was the two layers of prodex would create the airspace and since the fiberglass had air inbetween the fibers, it could only add to the r value not take away.
Does anybody have a contact at prodex to get some accurate technical data?
Old 01-04-2011, 10:01 AM   #7
x
XXXX , XXXX
Mattkroff I have done my belly pan and used rigid styrofoam cut into 2" strips as spacer blocks. It was glued and nailed to the floor using the nails with large plastic washers. Then the prodex was glued and nailed to the styrofoam and all the edges and seams were sealed up with aluminium foil tape. Taping the seams took longer than installing the insulation. To do the shell you will of course have to skip the nails and just glue the strips to the inside of the shell. There is glue made specifically for stryofoam. Let the glue set up for a day before installing the prodex.
I hope this helps with your plans.
Chris.
P.S. here is a link to my thread starting at the point where I insulated the belly. The pics will help and there is a more detailed explanation of the process.
http://www.airforums.com/forums/f36/...tml#post908035
Old 01-04-2011, 10:34 AM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Mattkroff
For home construction insulation is usually installed with the vapor barrier on the inside (warm) wall. Condensation will occur on the cold side and will evaporate to the exterior since this exterior envelope does not have a vapor barrier.
I believe that using this same logic for an AS trailer is not valid since the outside skin is alluminum which also is a vapor barrier (to my mind). So I think your sandwiched insulation idea has merit. However, I would think that using styrofoam instead of fiberglass would be better as there would be a small air gap between the Prodex and the styrofoam to allow some air flow to evaporate condensation. Also the r value for styrofoam is higher than for fiberglass. On the other hand with all the window area that an AS has, any incremental increase in wall insulation value may not mean much in terms of overall heat loss. In the end, make your own decision on how you want to insulate your AS and the test results will come later.
Dan
TouringDan is online now   Reply With Quote
Old 01-04-2011, 10:55 AM   #9
SilverHoot's Avatar
1967 24' Tradewind
I used Prodex
I did exactly as you are stating I used Prodex cut into strips for spacers between the shell and Prodex and then again between Prodex layers. I did call the number (720)733-1661 on the insulation4less website and verified that what I was doing would be effective. They were reluctant to respond as they usually do not provide technical assistance for buyers of such small quantities, just contractors.
Old 01-04-2011, 11:49 AM   #10
ddstech's Avatar
Folsom , California
Silverhoot, are you pleased with the results? How's the temperatures in the summer?
Old 01-04-2011, 12:16 PM   #11
SilverHoot's Avatar
1967 24' Tradewind
Matt,
Mine's still a work in progress, I'm still chasing down leaks and awaiting rivets right now. If you are familiar with Redding...you know I will be able to let you know the effectiveness, but not until this summer.
Old 01-04-2011, 12:59 PM   #12
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Good thinking. Here's why it won't work
The mechanism:
The primary source of vapor will be from the inside. Human breath raises the humidity. There is a temperature difference in the skin between top and bottom of the trailer, and from side to side during the day, that sets up a micro-circulation. The interior air gets circulated over time into the space between the shell. The humidity reaches out towards the outer skin until the air cools enough to reach the dew point, then it condenses and sits, or enough collects, drains.
Why this complicates it:
When there is a temperature difference between the inner and outer surface, the gap usually takes on an intermediate temperature. If there's a single layer of prodex in air, each side takes a 1/3rd 2/3rd split of the temp difference (so eg: 60F inside and 90F outside, the average inner space is 75F, with prodex each side will be 70F and 80F.) As you know, temperature falls down a hill, and the steeper the hill, the faster it falls. So therefore, having a layer of prodex is 50% more effective than a single air cell or layer of insulation. Two layers improves the convection/conduction by 66% instead of 50%, but radiatively insulates at 99% (two layers) around 96% (1 layer).
Fiberglass insulation works primarily by preventing airflow to reduce convection, though it's moderately effective at blocking radiation.
Hmmm, moisture.
So, the moisture is mostly likely to condense on the outermost surface below the air's dew point. Often, this is inside the inside skin on a cold day! However, it'll also be the inside of the outside skin. If you use this fiber/prodex sandwich, it'll be both between the outer skin and the prodex, but also between the prodex and the fiberglass.
I would skip the fiberglass, and arrange for two sealed prodex layers, spaced 1/3 and 2/3 between the inner and outer wall. I would paint the unseen from ground roof area with a reflective white paint, as covered in other threads, and I would install solar panels in such a way as to shade a large portion of the roof, reducing thermal load in that area.
Side note: the AS shel is its own radiant barrier if cleaned to a shiny state. Got black goop in your end caps? Buy some silver krylon and spray it silver first and you'll reduce radiant heat into the end caps by 20-30% just by doing that.
TX-16
Dave Park is offline   Reply With Quote
Old 01-04-2011, 01:10 PM   #13
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Chris.
Hi Chris;
You are sharp as a tack Chris and on top of it all. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
Old 01-04-2011, 01:10 PM   #14
VIKING's Avatar
Boulder Creek , California
I installed my Prodex with no spacers between the shell & insulation. There's just a 1" gap between layers of Prodex.
It outperforms the original pink & yellow stuff by many miles. I don't think three 3/8" spaces are going to outperform one 1" space by much, if any, and it will take you a LOT longer to arrange and attach all of the spacers and such.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 01-04-2011, 01:14 PM   #15
Dave Park's Avatar
2005 22' Safari
Indeed. Two layers will be at most 1.32 times as effective as one layer.
You'll get a far better result by using butyl tape to insulate the inner skin from the ribs as best you can. The rinse are neat little fins that equalize the inner and outer skin temp wherever they can. The ribs are very effective heat pipes without butyl tape.
TX-16
Old 01-04-2011, 01:47 PM   #16
boatdoc's Avatar
1973 Argosy 26
Hi SilverHoot;
Prior to insulating my 26' Argosy i have done plenty of research. Final decision was made to use Prodex with special installation technique. In the walls I have glued 5/8" low grade urethane strips on the inside of outer skin next to ribs with one strip in the center running vertically. Each and every horizontal strip was cut 1/8" short of vertical strips to allow moisture to drain all the way down. Prodex was cut to panels 2" larger on each edge. Panels were glued to the urethane strips and the side of the ribs. After glue was dry the excess Prodex was trimmed 1/16" past the surface of the rib. My wiring was ran over the top of Prodex. Inner skins were able to compress the 1/16" edge of Prodex which made a better air tight seal between two separate chambers. In direct sun and temperatures of 102 degree I only run my 15000 BTU low profile Carrier on lowest setting. Thanks, "Boatdoc"
Old 01-04-2011, 01:59 PM   #17
ddstech's Avatar
Folsom , California
This is great info. Any chance you took pictures during your installation?
Old 01-04-2011, 02:10 PM   #18
SilverHoot's Avatar
1967 24' Tradewind
Thanks BoatDoc! I like your idea of leaving a 1/8" gap for moisture drainage and will incorporate your idea. I've said it before and I'll say it again "This forum is GREAT!"
Old 01-04-2011, 02:42 PM   #19
VIKING's Avatar
One of the things not mentioned here or in other threads I have seen on insulation installation: The last step of installing the Prodex is to seal around all edges to maintain a sealed airspace, yet it is discussed as if the spaces are not being sealed. I would bet the surface of the insulation creates a much better vapor barrier than the aluminum skins did originally, what with all of the rivet holes and unsealed seams. In fact, there's little chance of moisture getting into the wall from the inside now at all.
Rich the Viking
Old 01-04-2011, 05:35 PM   #20
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Although it is desirable to allow any liquid water to travel from ceiling to floor so we might* have a chance to observe it - the chimney effect of an open cavity airspace in our Prodex installs (from floor to ceiling) will reduce R-value overall.
Cold will drizzle down and warm percolate up allowing faster diffusion whichever way we want to look at it. That is another point that fiberglass has to its merit - true dead airspace within its matting.
I expect to use white 3/4" foam cut to fit for a horizontal baffle every eighteen inches inbetween the two layer method - and the shell layer of Prodex held off from the outer skin by strips of Prodex.
I like the sandwich method of OP for areas needing more sound proofing, helps with both inside-to-out and outside noises in. When a Home Depot closed up here I nabbed two cases of their "Handi" wrap 2-inch thick by 5-foot long rolls for 90% off and plan to use them near the seating and sleeping areas from top of windows down. Also plan to use it around the four speakers cut into the liners for better sound where the patches to remove them would be uglier than the speakers...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Dow Safetouch insulation 2vets General Interior Topics 3 07-13-2011 08:25 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 11:10 PM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 08:22 AM
Insulation lmassa Belly Pans & Banana Wraps 4 02-24-2011 11:17 PM
Insulation CampUnger General Interior Topics 3 02-13-2011 08:52 PM
