Old 08-25-2011, 11:16 AM   #43
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A quick search here showed VIKING posted on about the bubbles going flat - remember its a different kind of heat, zero cooling breezes locked up under the sun-baked shell.
Also - both types list 180F as their upper limits, if temps go above that the Prodex has a better chance of returning to normal than the bubble...
I cut window sunshades from the Prodex and had them kicking around my truck bed & in the windows for almost three years and 60,000 miles now and they are getting a little flimsy and dog-eared but bubble would've been gone a long time ago.
Old 08-25-2011, 11:29 AM   #44
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have a sun screen window protector/reflector with bubbles that I bought in 1984. Not one, not one, of the bubbles has deteriorated or gone flat.
Old 08-25-2011, 12:08 PM   #45
Wabbiteer's Avatar
1972 29' Ambassador
Hey Melody Ranch - is it "Reflectix" brand exactly or just that style?
Old 08-25-2011, 12:43 PM   #46
VIKING's Avatar
Boulder Creek , California
"I opted for the prodex, partly due to Uwe's recommendation of it. The manufacturer claims it holds up better to high-heat situations like Airstreams walls encounter ocassionaly. Their claim is that heat causes the air in the bubbles to leak out and allows the foil layers to collapse against each other. I couldn't verify that, but I do know the Prodex was easier to handle then the Reflectix, because it was more rigid."
The info about the bubbles going flat in Reflectix is from the Prodex website and should be treated as such.
Cheers!
Rich the Viking
VIKING is offline   Reply With Quote
Old 08-25-2011, 02:00 PM   #47
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Thanks so much for the background.
timzog is offline   Reply With Quote
Dow Safetouch insulation 2vets General Interior Topics 3 07-13-2011 07:25 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Fiberglass vs Cotton Insulation GeocamperAS General Interior Topics 13 03-09-2011 07:22 AM
Insulation lmassa Belly Pans & Banana Wraps 4 02-24-2011 10:17 PM
Insulation CampUnger General Interior Topics 3 02-13-2011 07:52 PM
