Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-15-2002, 11:59 AM   #1
jabra's Avatar
Profile:
Question Moving the Rear Bath Forward?
I have just acquired a 1976 Argosy 28' trailer and it has the rear bath. I was wondering if it's a very big deal to move the bath to mid-ship and covert the back into a double bed area? Has anyone done this? THANX!
Argonut
jabra is offline   Reply With Quote
Old 10-15-2002, 12:58 PM   #2
Profile:  LOST , Hawaii
Depends on what you consider a bid deal. You will need a new black water tank, the toilet mounts to it. You will probably need a new gray water tank. These will have to be designed to fit within the confines of the frame and you should consider how you will drain and vent them. New supports will be needed, the AS method of running the furnace duct through the box would be nice to maintain. You will also have to move wiring and make changes to the fresh and hot water lines. It would take some planning, but if you did it right should not be all that bad. My motorhome came with a rear bed, if it didn't it would have one in it's second life.
John
74Argosy24MH is offline   Reply With Quote
Old 10-18-2002, 05:09 PM   #3
gerbermania's Avatar
Profile:
i have not done it yet, but i am currently in the design stage of moving my rear bath to just the rear corner, more similar to some of the newer 23' safari.
since you only want to create a double-bed, and not a king size bed, you may consider this as well.
attached are before-after diagrams. notice that i have the toilet staying in the same spot, it simply rotates 45 degrees so that it faces forward. all the other plumbing and vents would still need to be re-routed, but at least the black water tank can stay in the same position. i realize you may not have my particular design, but there might be something about a corner bath that could work for you.
christopher
gerbermania is offline   Reply With Quote
Pingbacks are On
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Rear Bath Floor Droop bdbluegrass All Argosy Trailers 4 05-04-2005 08:44 AM
25' rear dbl ctr bath? FlynG Our Community 2 08-26-2003 04:25 PM
Rear Bath Upper Wall Cracking w5wi General Interior Topics 0 07-20-2003 08:13 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
SEO by vBSEO 3.1.0
