Old 03-19-2010, 10:28 AM   #1
Meeker's Avatar
1974 29' Ambassador
Columbus , Ohio
Moving AS tomorrow and need advice
Hello everyone!
I own a 29' 1974 Ambassador and will be moving it tomorrow. Here's the catch. The PO wanted to wait until the ground hardened a little here in Ohio before we moved the trailer from it's current home. Over the past month we've been working on it where she sits now. The other day I started the process to remove and fix the interior front end cap. The cap is still in (not for long ) but all of the rivets have been removed around the cap. Everything is still fairly secure. We will be moving the trailer about 15 miles on the interstate. Do I need to button everything up the way it was or can I get away with just making sure everything is secure with strategically placed rivets? Just so you know, I never would have started the end cap removal had I known we would be moving it tomorrow.
Meeker is offline   Reply With Quote
Old 03-19-2010, 10:33 AM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Your trailer will flex a lot more than you may imagine....even on smooth roadways. Without seeing your whole picture T would secure it.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-19-2010, 11:43 AM   #3
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Maybe Cleco's would work for the trip... it might save you from re-riveting and drilling everything. I'll defer to someone with more expertise on Clecos, but it's an idea.
hampstead38 is offline   Reply With Quote
Old 03-19-2010, 11:43 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are going to secure things in place with only a few rivets I would use washers on the rivet to increase the surface area supporting the cap. This will aid in preventing the cap from cracking at the rivet.
The number and placement of the rivets is a hard one. I would aim for those rivets that will be in shear around the bottom edge, to take the weight and some at the top, to stop possible rotation. a dozen should be enough for that distance.
2004 Excursion 4x4
Just got my first Airstream and moving in tomorrow canadiangent Member Introductions 2 01-05-2010 08:08 PM
looking at 25' tomorrow - need advice weldvair General Interior Topics 19 01-03-2010 08:37 PM
Hollywood Couple Moving to Austin in Brand new '09 A/S. Need Advice jamin242 Full-Timing 25 02-11-2009 11:54 AM
Tomorrow, Tomorrow, I can't wait until tomorrow! thecatsandi 2006 - 2010 Classic (all lengths) 8 04-05-2006 03:55 AM
Tomorrow... Tomorrow... Foiled Again Off Topic Forum 21 04-02-2006 06:43 AM
