Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-22-2002, 10:27 PM   #1
overlander
Guest
Profile:
Posts: n/a
moved and tore loose what happened
i have a 1977 air stream overlander 27'
here is my question has anyone seen this, some of the interior panel walls have pulled away from and moved sideways from the interior skin. they heve tore loose about a half inch in some places. the peice of channel that the walls where connected to is still solidly connected to the interior skin.
my trailer is setup with rear bath, the bed room is next, then kitchen, then the living room. i was woundering what might of coused this, and is this normal for older airstreams. from what i can see the frame is not bent.
three walls on the left side have done this, from the fridge back.
i am planning on replacing the walls.
Old 09-23-2002, 02:44 AM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Unhappy Odd
This, IMHO, isn't normal.
I know if it were mine, I'd looking into WHY very seriously.
Good luck to you and, plse keep the group informed as to what you find. Pictures would be a big help.
ciao
53flyingcloud is offline   Reply With Quote
Old 09-23-2002, 08:30 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Your wall movement is an excellent example of square tires and/or lack of proper tire, wheel, hub and drum balance.
The worse the unbalance, the faster the walls will move. Replacing the walls, won't stop a thing. One way the running gear can be balanced can be seen on our web site, inlandrv.com Click on "articles" and then click on wheel balancing.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 09-24-2002, 06:40 PM   #4
overlander
Guest
Profile:
Posts: n/a
hmmm..
i was thinking along those lines. i think i would be able to feal that kind of imbalance when i'm towing my trailer. i might have somone ride inside for a test.
i'll be getting new tires soon they will be balanced then. i was thinking that probably what coused this was ruff gravel roads, alaska has lots of them. i resently purchased this trailer, and i think i am the third owner. i'm just trying to fix it up some.
the tires arn't that large i dont think that the vibration would be that suvier, if they were imbalanced. raidial tires dont get flat spots,and with bias ply tires flat spots go away when the tires warm up. there 700 15's or somthing like that.... it's not like i have 40 inch swampers on it.
my trailer tows really well and i havn't seen or felt any kind vibration comming off of it. the damage isn't that bad and its only on one side and the other walls are still intacked and in place. i think the problem is it has seen some hard miles on bad roads. i think it was abused. i would say take it easy on ruff roads or yours might end up like mine.
Old 09-24-2002, 06:44 PM   #5
Commercial Vendor
You may also have one or two bad axles. If they are, the trailer will bottom out when it hits bumps. New tires or balancing won't be a help.
inlandrv.com
airstreamparts.com
Inlandrv.com
Old 09-24-2002, 06:50 PM   #6
overlander
Guest
Profile:
Posts: n/a
i have checked that out
i when i went through the wheel bearings and inspected the brakes. i looked closley at the axles and spindals and the torshon bars they look ok to me. shocks are good too. everything is in good order.
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
