Old 11-18-2012, 01:18 PM   #1
MontyV's Avatar
1994 34' Limited
Salem , Oregon
mounting points
how can I determine where and to what depth it is safe to mount something to a wall. For example a flat screen TV.
MontyV is offline   Reply With Quote
Old 11-18-2012, 02:01 PM   #2
Ottawa , ON
For that kind of mounting, be sure to go into a stringer. The aluminum itself won't hold up a TV set, IMHO.
Stringers can be found by looking for rows of rivets. They are used to fasten the interior aluminum sheets. Sometimes though a row could simply be holding two sheets together, so have a close look at where you want to put fasteners.
Us either stainless steel or aluminum screws, BTW. Regular steel will corrode.
Old 11-18-2012, 02:29 PM   #3
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
I mounted our two flat panels to interior wood divider panels with anchors and screws without any problems. One was mounted on a wood bedroom wall and the second on the divider between our dinette and the refrigerator. If you have a spot available that saves drilling into the interior aluminum walls.
wolverine is offline   Reply With Quote
