Old 10-11-2002, 04:41 PM   #1
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Moth Balls
Now have fun with this one! I can take it. Where does one put them? Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 10-11-2002, 04:48 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Must....fight....urge.....to......respond......to. ......this......thread.......
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 10-11-2002, 09:12 PM   #3
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Moth Balls
Bobby. Take some ex-lax............!
Old 10-12-2002, 07:40 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Enough of this Tomfoolery!!
Once whilst dumping my black tank at home, (in my septic tank, of course!) My wife, Diane observed a mouse jump out of the back bumper compartment. I concured that when we had her plugged in at the farm market, the little buggers travel up the electrical cord, into the Airstream. So, keep some in the back bumper compartment, as that seems to be the main entrance for vermin. We also keep "sticky traps" in locations where mouse terds have been observed.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-12-2002, 08:56 AM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Mice
A couple of years ago, we had a real rainy spring and my truck just sat, unused, for about a month. When I started it up, it was quite sluggish. I found the tube into the air filter totally blocked with a field mouse nest, complete with a family of 4 little ones.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 10-12-2002, 04:14 PM   #6
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Moth Balls
I knew I came to the right place for good advice..........tanks a lot!! Tom
Old 10-13-2002, 04:57 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
John,
Interesting about the field mouse nest. I have heard to check lawnmower and power equipment engines after winter because mice can build a nest inside the flywheel cover to winter over. By the way, had a friend go out one morning and start his truck only to hear a terrible noise. A cat apparently had been sleeping on or near the manifold and jumped straight into the fan. That must have been a mess.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-18-2002, 07:13 AM   #8
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Moth Balls
davidz, so I should get a cat??? Tom
Old 02-02-2003, 12:01 AM   #9
hex
hex's Avatar
Lightbulb Kirby Vacumn cleaner Vaporizer
My mother used to have a Kirby Vacumn cleaner accessory that you placed moth balls in and attached to the machine. I think the balls went on the suction side and the hose was placed on the exhaust side. Anyhow the moth balls vaporized and "moth ball gas" was pumped into the closet etc thru the hose if I recall correctly.
Seems that the hose could be inserted in belly of the trailer and into the duct of furnace as well and perhaps it would drive the mice, bugs etc out...or at least nuts.
Does anyone remember or know of the Kirby device?
My mom is deceased but I have the old Kirby somewhere, just not sure about the moth ball vaporizer.
Does anyone see a downside to this? Corrosiveness perhaps?
hex is offline   Reply With Quote
Old 02-02-2003, 10:27 AM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Moth Balls
Greetings Hex!
The Kirby accessory that you are describing was part of the accessory kit for the Kirby Dual Sanatronic 80 dating to the late 1960s to early 1970s. I have the full acessory kit inlcuding the moth ball attachment that replaces the dirt bag on the exhaust side. It has never been used, and I am not absolutely certain as to its effectiveness. The next time I am home, I will get it out of the box and see if it fits my later model Kirby - - the Dual Sanatronic 80 wore out about 1984 and my later (1998) Kirby didn't have anything similar in its accessory kit.
Kevin
Kevin D. Allen
AIR #827
Old 02-03-2003, 11:15 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Moth Balls In Back Bumper Compartment
Went on "mouse patrol" Sunday, and saw no evidence of mice in the Airstream. As I said before, I keep an open box in the bumper back in the bumper compartment. Either the mothballs are working, or all the mice are hibernating for the winter!
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
What's the deal with those pink flamingos? Gwen Off Topic Forum 67 06-07-2017 05:05 PM
A new kind of "Bounce" plan COArgosy78 Off Topic Forum 47 01-10-2004 02:04 PM
Speaking of hitch balls Ken J Hitches, Couplers & Balls 11 10-18-2003 10:09 AM
Trailer Guardian Justin Our Community 6 07-13-2003 09:05 AM
trailer hitch height '68 Sovereign sectionc Axles 7 01-25-2003 09:11 PM
