Old 01-04-2010, 07:01 PM   #1
MrsGlisten
1959 22' Caravanner
1963 24' Tradewind
Anderson , South Carolina
Most despicable findings in vintage units
Several weeks ago, I brought home a really good-looking 1963 Safari. It pulled great. It has a straight body with only a few dents and scratches. The interior actually looked good. It had been renovated 'after a fashion'. Interestingly, it has an 8,000 lb axle. The floor had been covered with OSB, then stick down tile. There is a dinette, kitchen area, side toilet, and double bed in rear. I decided that I would take out the double bed and investigate the rear. Boy, am I glad I did! The toilet and sink both drained into a large wooden pan which was lined with fiberglass. There was a 4 inch pipe which drained out on the ground. There was no water access to the toilet to assist with flushing. The fiberglass/wood 'tank' had leaked on the rear floor which had rotted through and the frame under the rear is badly rusted. Nothing which cannot be repaired, but I am surprised by the wood/fiberglass tank which drained directly to the ground.
My tentative plan is to put in a typical gray water tank and a solar powered composting toilet.
MrsGlisten is offline   Reply With Quote
Old 01-04-2010, 07:14 PM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
Gray Tank & Composting Toilet Installation
Hi Gooseylucy,
Sorry to hear about your misfortune! Here are some photos of our gray tank installation and some links to info on our composting toilet which you may find interesting. Good luck with you project!
FLYNCLD
http://www.airforums.com/forums/blog...tallation-144/
http://www.airforums.com/forums/blog...on-update-166/
The Eco-Discovery Tour-Our Composting Toilet
FLYNCLD is offline   Reply With Quote
plumbing, tanks, black tank
STL RV show vintage units jcanavera Our Community 1 12-19-2006 11:56 PM
Vintage sub-units? Midamrail WBCCI Forum 47 12-10-2006 09:53 AM
Vintage Units VS New Units Cstar On The Road... 4 05-07-2004 10:22 PM
To all owners of vintage units altastars General Interior Topics 36 05-07-2004 11:37 AM
General heights of vintage units? summerkid Airstream Trailer Forums 6 04-01-2004 11:53 AM
