Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-28-2006, 12:33 PM   #1
Blu_Hwy_Lady
Blu_Hwy_Lady's Avatar
Profile:  1972 23' Safari
Placitas , New Mexico
Mosaic Tiles on vertical surfaces?
Using the search function, I discovered a couple of thread where people discussed using mosaic tile on the bathroom floor. What I'm wondering is how it would hold up on vertical surfaces like the thin fake wood strips between the tambour doors and even on the fake walnut surfaces. Seems like it would be a great way to cover it up rather than ripping it out. I don't know that I would necessarily grout them, perhaps just placing them close together would give a good effect.
BTW, in searching past threads I found a post of a description of an art project type trailer by Cat from 7-02. It sounded fantastic, sort of the kinds of things I'd like to do. However, there were no pictures. Cat, if you're reading this, can you post pics of your Excella or links to where the pictures live. It sounds fascinating.
Airylle (Susan's 1972 Safari) featured for 5 nanoseconds in the movie Wild Hogs
pulled by Jak the Blue Mule (Bill's 2001 Dodge Cummins)
and
Jupiter (the Golden Retriever puppy)
Athena (the road kitty)
Blu_Hwy_Lady is offline   Reply With Quote
Old 10-28-2006, 01:35 PM   #2
Craftsman
Guest
Profile:
Posts: n/a
There may be a way to use moasic tiles on a vertical surface but I doubt in the long run that it would hold up in an Airstream because of the flexing, vibration and bumping while traveling. I find it hard to believe that it would hold up on floors in an Airstream without cracked and disintegrating grout lines. It is used in large motor homes but i would think the chassis is stiffer and somewhat isolated from the road by better suspension and the height. I do know that there is a flex agent that can be added to the grout but I wonder if it would be enough. Another problem is; tile is very heavy. Something to think about. I just finished tiling two kitchens and a bathroom both walls( back splash) and floors but they're not moving.
Old 10-28-2006, 02:12 PM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
It would be nice if you never take it on the road, too much flexing.
How about painting see
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 10-28-2006, 02:31 PM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Ditto on the tile is way-too-heavy!
Cat was member #118! She last posted here earlier this month. If you are seeking her input I'd suggest a PM with this thread's URL to ask her to look in. I remembered pictures of Cat's entry door only. I see that it's in her photo gallery: http://www.airforums.com/photo...500&userid=118
Old 10-29-2006, 10:54 AM   #5
Blu_Hwy_Lady
Canoe: Thanks of the links. Love Cat's door. As far as the tiles, I'm thinking those tiny little mosaic tiles and using them as an accent around the tambours not tiling the whole coach. I faux painted the inside. (See pics) I think painting the fake wood would be too much.
Name:	faux painting detail.jpg
ID:	27670  Click image for larger version
and
Old 10-30-2006, 10:35 AM   #6
Mel
Mel's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
We used small glass tiles (sparingly) on a vertical surface in our Safari and it's been fine. We have gone over some pretty nasty washboard roads that have opened cupboards, yet the tiles are still intact. If you go this route, I would suggest using a silicone adhesive to attach the tiles to the wall and fill in between - don't use grout. Have a look here, they're the yellow and turquoise tiles that make up our kitchen counter backsplash.
Mel
1960 Caravel "Boris"
1967 Safari "Sparky"
My Photos
Mel is offline   Reply With Quote
Old 10-30-2006, 02:04 PM   #7
Blu_Hwy_Lady
Wow, great restoration job Mel. It looks wonderful. Your use of tile is sort of what I had in mind as a border treatment. Thanks for the advice about the silicone adhesive.
and
Old 10-30-2006, 05:04 PM   #8
silverleeper
silverleeper's Avatar
1960 18' "Footer"
Hi, Use the silicone adhesive like you would use regular tile adhesive with a notch trowel. The tiles will want to slip a little so find a way to hold them. The tile I put in was just above the counter so I used a narrow piece of wood. After the tile sets then use a high quality silicone to fill the gaps. It comes in many colors.
Lee
The more I learn the less I know!!
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
silverleeper is offline   Reply With Quote
Old 10-30-2006, 05:08 PM   #9
Blu_Hwy_Lady
Got Pictures Silverleeper? Also, what is the brand of silicone adhesive?
and
Old 10-30-2006, 05:19 PM   #10
silverleeper
1960 18' "Footer"
Hi, It was 3M. Read the tubes carefully to make sure you get what your looking for. Stay away from latex (water based).
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
Old 10-30-2006, 06:24 PM   #11
silverleeper
1960 18' "Footer"
Correction, The caulk I used on this application was GE.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
Carpet tiles are the answer. LTD30 Repairing/Replacing Floor &/or Frame 3 12-05-2006 08:02 PM
Cork floor Charcigar Repairing/Replacing Floor &/or Frame 42 03-02-2006 01:25 PM
Rubber floor tiles??? slmontgomery Repairing/Replacing Floor &/or Frame 11 12-08-2005 10:14 PM
Asbestos in floor tiles? dsakaki General Interior Topics 5 10-01-2005 10:30 AM
