Old 10-28-2006, 12:33 PM   #1
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
Mosaic Tiles on vertical surfaces?
Using the search function, I discovered a couple of thread where people discussed using mosaic tile on the bathroom floor. What I'm wondering is how it would hold up on vertical surfaces like the thin fake wood strips between the tambour doors and even on the fake walnut surfaces. Seems like it would be a great way to cover it up rather than ripping it out. I don't know that I would necessarily grout them, perhaps just placing them close together would give a good effect.
BTW, in searching past threads I found a post of a description of an art project type trailer by Cat from 7-02. It sounded fantastic, sort of the kinds of things I'd like to do. However, there were no pictures. Cat, if you're reading this, can you post pics of your Excella or links to where the pictures live. It sounds fascinating.
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
and
Jupiter (the Golden Retriever)
Blu_Hwy_Lady is offline   Reply With Quote
Old 10-28-2006, 01:35 PM   #2
Craftsman
Guest
Posts: n/a
There may be a way to use moasic tiles on a vertical surface but I doubt in the long run that it would hold up in an Airstream because of the flexing, vibration and bumping while traveling. I find it hard to believe that it would hold up on floors in an Airstream without cracked and disintegrating grout lines. It is used in large motor homes but i would think the chassis is stiffer and somewhat isolated from the road by better suspension and the height. I do know that there is a flex agent that can be added to the grout but I wonder if it would be enough. Another problem is; tile is very heavy. Something to think about. I just finished tiling two kitchens and a bathroom both walls( back splash) and floors but they're not moving.
Old 10-28-2006, 02:12 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
It would be nice if you never take it on the road, too much flexing.
How about painting see
'77 Sovereign Intl 31' CB
Old 10-28-2006, 02:31 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Ditto on the tile is way-too-heavy!
Cat was member #118! She last posted here earlier this month. If you are seeking her input I'd suggest a PM with this thread's URL to ask her to look in. I remembered pictures of Cat's entry door only. I see that it's in her photo gallery: http://www.airforums.com/photo...500&userid=118
5 meter Langford Nahanni
Old 10-29-2006, 10:54 AM   #5
1972 23' Safari
Canoe: Thanks of the links. Love Cat's door. As far as the tiles, I'm thinking those tiny little mosaic tiles and using them as an accent around the tambours not tiling the whole coach. I faux painted the inside. (See pics) I think painting the fake wood would be too much.
Name:	faux painting detail.jpg
ID:	27670   Click image for larger version
and
Old 10-30-2006, 10:35 AM   #6
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
We used small glass tiles (sparingly) on a vertical surface in our Safari and it's been fine. We have gone over some pretty nasty washboard roads that have opened cupboards, yet the tiles are still intact. If you go this route, I would suggest using a silicone adhesive to attach the tiles to the wall and fill in between - don't use grout. Have a look here, they're the yellow and turquoise tiles that make up our kitchen counter backsplash.
Mel
Mel is offline   Reply With Quote
Old 10-30-2006, 02:04 PM   #7
1972 23' Safari
Wow, great restoration job Mel. It looks wonderful. Your use of tile is sort of what I had in mind as a border treatment. Thanks for the advice about the silicone adhesive.
and
Old 10-30-2006, 05:04 PM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Images: 8
Hi, Use the silicone adhesive like you would use regular tile adhesive with a notch trowel. The tiles will want to slip a little so find a way to hold them. The tile I put in was just above the counter so I used a narrow piece of wood. After the tile sets then use a high quality silicone to fill the gaps. It comes in many colors.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-30-2006, 05:08 PM   #9
1972 23' Safari
Got Pictures Silverleeper? Also, what is the brand of silicone adhesive?
and
Old 10-30-2006, 05:19 PM   #10
1967 22' Safari
1960 Caravel
Images: 8
Hi, It was 3M. Read the tubes carefully to make sure you get what your looking for. Stay away from latex (water based).
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 10-30-2006, 06:24 PM   #11
1967 22' Safari
1960 Caravel
Images: 8
Correction, The caulk I used on this application was GE.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Carpet tiles are the answer. LTD30 Repairing/Replacing Floor &/or Frame 3 12-05-2006 08:02 PM
Cork floor Charcigar Repairing/Replacing Floor &/or Frame 42 03-02-2006 01:25 PM
Rubber floor tiles??? slmontgomery Repairing/Replacing Floor &/or Frame 11 12-08-2005 10:14 PM
Asbestos in floor tiles? dsakaki General Interior Topics 5 10-01-2005 10:30 AM
