Old 10-18-2011, 03:08 PM   #1
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Mosaic tile back splash
Installed a glass mosaic tile back splash and it has stood up to 3 ruff trips. Looks like it will last.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 10-18-2011, 04:00 PM   #2
Lily&Me's Avatar
Normal , Illinois
Nice job!
Maggie
Old 10-19-2011, 07:46 AM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
doug&maggie - Thanks for the kind word it was a fun project.
Tim
TAC MI 14
Old 10-19-2011, 08:57 AM   #4
jerseylilly's Avatar
1964 19' Globetrotter
Richards , Texas
Did you use regular grout materials? I've got one small area that I need to put something....by my stove where the counter top stops...and up the wall.
We looked at one airstream trailer that had all kinds of tile done in the bathroom...and it was showing cracks from movement while traveling. I was wondering if there was some kind of flexible grout that could be used instead of the conventional kind.
jerseylilly is offline   Reply With Quote
Old 10-19-2011, 10:16 AM   #5
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I also considered some tile for the bath but ruled it out as the walls had much more movement than the kitchen area behind the cook top.
I'm not as much concerned with grout cracking as that is easy to repair. My main concern was with the mortar being able to hold to the walls.
I used the following flexible mortar and grout:
Mapei Adesilex P10 Mosaic & Glass Tile Mortar w/Polymer.
Mapei Keracolor Unsanded Grout w/Polymer.
This stuff is also designed to handle temp swings and freezing.
Good luck,
Tim
TAC MI 14
Old 11-02-2011, 10:56 AM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
thanks for posting. If I ever gut and design a new interior, this is definitely something I'm going to try for an inside shower. The other thing I really wanted to do was install some waterproof LED's along the sides of the glass, but not sure how well it would work. Looks really nice. Great job.
robwok is offline   Reply With Quote
Old 11-05-2011, 08:41 PM   #7
jenner 515's Avatar
1970 25' Caravanner
Arvada , Colorado
Very nice, I was just thinking about doing a low (4" or so) countertop lip. Thanks for posting and the info.
jenner 515 is offline   Reply With Quote
Old 11-05-2011, 10:25 PM   #8
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
That is a beautiful kitchen! Outstanding work!
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
Max Well is offline   Reply With Quote
Old 12-24-2011, 03:31 PM   #9
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
Tkasten - Love the tile backsplash. We are wanting to do some carrera marble subway style tile on our kitchen backsplash area. My questions is what did you adhere the tile to? We also have a 65 the walls are the vinyl and have been painted once with oil based paint. Any advice would be greatly appreciated.
Happy Holidays
Like this tile:
NicheVintage is offline   Reply With Quote
Old 01-01-2012, 01:10 PM   #10
Spencer , New York
nice! i would like to do this in the bathroom to one wall. wonder if it would hold?
jennygt is offline   Reply With Quote
Old 01-01-2012, 02:06 PM   #11
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
"Island Girl" Backsplash
I was hesitant about using tile backsplash for all the reasons mentioned. We used a very sticky backing from HD (TileSetting Mat). Believe me...the tile will go no where and you don't have to worry about backing breaking and cracking. Because we were only tiling a small area we used a standard grouting material we got at HD. So far no problems. One thing I would suggest...when putting on your tiles, keep them slightly above (1/8" should be fine) the galley top. Use a flexible caulking...if not, standard grouting will crack under the first layer of tiles from the movement of the countertop and the grouting under the bottom layer of tiles.
PA TAC-5
WBCCI-4871
ID:	147978   Click image for larger version
ID:	147980   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 01-01-2012, 02:11 PM   #12
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I used the following flexible mortar and grout as stated above.
I applied the mortar right on top of the painted alum. We've made several trips, many to the hunting land (bumpy roads) with no cracks. Use the right products, a good tile store with help with that info. I also waited nearly two weeks before travel allowing plenty of time for curing.
The glass mosaic I used is light compared to tile.
Tim
TAC MI 14
Old 01-01-2012, 02:14 PM   #13
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
PA TAC-5
WBCCI-4871
It look great! We used the same mat for our bar at home, it works great!
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
5 wks airstreaming and now it is back to work Lothlorian On The Road... 10 07-29-2011 11:23 AM
Ceramic Tile Re-Glueing??? TomR Off Topic Forum 14 07-25-2011 01:36 PM
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 02:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
