Old 03-22-2015, 05:00 PM   #1
gpt
2014 25' FB Flying Cloud
sequim , Washington
moisture control
we just finished a week of kicking about in WA state. it was raining a good part of the time, quite heavily. the temps were cold enough, mid 40s to promote furnace use. as a result, we had quite a bit of moisture build up on the windows.
we don't have those nifty plastic caps on the fantastic fan openings so could not leave them open as they would just close down with the rain coming down. we do use the vent over the stove when cooking.
i am now wondering if it would be advisable to simply open the vents in the toilet and shower areas, no fans going, as they do have caps which would keep the rain from entering.
your thoughts on how to about controlling moisture buildup are appreciated.
gpt is offline   Reply With Quote
Old 03-22-2015, 05:04 PM   #2
dznf0g's Avatar
Oswego , Illinois
When 12v shore power is available, I run a small dehumidifier:
NewAir AD-250 25 Pint Portable Room Dehumidifier
-Rich-
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
Heat exchanger for moisture control? SilvrSausage Roof Vents, Skylights & Fans 3 10-13-2007 01:00 PM
Moisture source noiva Classic Motorhomes 6 10-11-2006 12:02 PM
