Old 01-17-2016, 06:43 PM   #1
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Modified Rear Twin from 2-34" Wide to a 34" and 39"STD Twin
We have a 1986 rear twin, center bath 25' trailer. By replacing the metal slates with ones 5" longer I could convert one bed to a standard width twin. The bathroom is also 39" deep so the setup look like it should be that way. The only other change was cutting a new plywood top. I used 3/8" DF material, just to keep it from sagging. Material used: 1X2" aluminum square tubing, same width but 1/4" thicker than original. Tip up access still works too.
sgschwend is offline   Reply With Quote
Old 01-17-2016, 06:52 PM   #2
1986 31' Sovereign
columbia , South Carolina
Very nice! My wife and I were discussing bedroom options just this afternoon. I assume you will have a mattress custom made?
rolledxj is offline   Reply With Quote
Old 01-19-2016, 09:28 PM   #3
sgschwend's Avatar
1986 25' Sovereign
Images: 13
The wife points out that AS no longer uses internal springs in their mattresses.
Her plan is to order standard foam twin mattresses and then using a foam saw cut them to fit. She will then sew the cover back on.
Thickness, 10", includes 2" of memory foam.
Old 11-10-2016, 08:33 AM   #4
Sovereign25's Avatar
1985 25' Sovereign
Hampton , Virginia
Thanks for the excellent idea on converting the roadside bed to a twin. I bought a twin X-long foam mattress and it worked perfectly.
Sovereign25 is offline   Reply With Quote
Old 11-11-2016, 04:56 PM   #5
St thomas , Ontario
Quick question- we pulled out our twins to put in a double or queen- does anyone know how much the twins weighed? Ours is an 87 sovereign
cojo75 is offline   Reply With Quote
Old 11-12-2016, 08:45 PM   #6
sgschwend's Avatar
1986 25' Sovereign
Images: 13
My guess is that the twin frame is about 20 pounds. It is really just a front and a few aluminum rectangular tubes. The decking is 1/4" think.
Also the mattresses we found on Amazon had independent springs, so we ended up with foam/spring mattresses.
1999 34' Airstream Limited Wide Body - 3 Axles - Twin Beds in rear- Dinette eBay Watch Airstreams on eBay 0 02-04-2014 07:00 PM
Carrier A/C std vs low profile Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 39 08-23-2007 05:13 PM
Std Reese wd hitch upgrade crispyboy Hitches, Couplers & Balls 2 04-27-2007 08:23 PM
Modified GMC/Overlander combo - request advice. escapeez Tow Vehicles 13 01-01-2003 02:27 AM
