Old 11-23-2009, 06:20 PM   #1
2004 25' Safari
Newmarket , Ontario
Mice, Mice, Mice
Have a 2004 Safari which I purchased new. Have stored the rig outdoors in a secure storage facility on gravel. Unit is completely emptied of ALL foodstuffs and cleaned before storage.
Checked the trailer last week and for the first time found obvious evidence of mice. Have checked every conceivable spot where the critters could get in but eveything appears sealed.
Am now in the process of attempting to eliminate the problem - bait, traps, etc.
Anyone out there who has experienced a similar attack know of a possible rodent point of entry that I may have missed ??
Jake is offline   Reply With Quote
Old 11-23-2009, 06:33 PM   #2
Kevin245's Avatar
Hello Jake,
Mice and leaks are the bain of many an Airstream owner. A mouse doesn't need much of an opening to access your interior. Common areas to look for are around gas line penetrations, the entry steps, wheel wells, and the rear bumper. You may also want to look around the A-Frame where it enters the body.
We had a few sheared rivets on the belly skin that was the point of entry for our last round of visitors. Five minutes, a few pop rivets and two mouse traps quickly resolved that problem.
We feel your pain.
Kevin
William C. Swinney
Old 11-23-2009, 06:38 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
What Kevin said and don't forget the frame by the tongue jack. It's like a mouse superhighway. This thread will help too. http://www.airforums.com/forums/f476/mouse-proof-57784.html
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-23-2009, 07:11 PM   #4
1994 34' Limited
austin , Texas
our cat was worthless
we went the humane way for a while with the live traps. but then had to declare war and started playin for keeps. live traps just not efficient enough to keep up with their hyper-reproduction. (the enclosed snap trap is the way to go.) seal up as best you can and keep a baited trap or two (w/ peanut butter) all the time. (even with a great seal job) if you trailer a lot, spaces will open enough to let the buggers in.
those enclosed snappers are safe in case you forget a trap in a dark cabinet.
dentwalk is offline   Reply With Quote
Old 11-23-2009, 07:20 PM   #5
Silverhobby's Avatar
Greeeneville , Tennessee
Another way to get rid of mice is to set up a pail with some water and a stick that hinges on the edge of the pail. Set it so that a mouse can "walk the plank" to get at the bait sitting on the end over the bucket. When he gets close, the plank tips and dumps him into the water. The delicately-balanced, hinged plank then returns upward for the next mouse.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-23-2009, 08:42 PM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Got a picture of this bucket trap? This sounds interesting.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-23-2009, 08:55 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Brad - Check it out
Richard
Old 11-23-2009, 08:58 PM   #8
2005 22' Safari
Gresham , Oregon
Too funny, but do you really get that many??
sempi2 is offline   Reply With Quote
Old 11-23-2009, 09:58 PM   #9
1971 25' Caravanner
scappoose , Oregon
What you have to do, is inspect carefully around the "basebord" areas, and the junctions of "bulkhead" areas. When tou think you found the likley spot, using a mirror is necessary, look inside.
If you see a little dresser, table, tv, and bed, then you'll know,,,, thats where they live.
rangebowdrie is offline   Reply With Quote
Old 11-24-2009, 06:29 AM   #10
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
In addition to the spots already mentioned also look at your drain exits - and ditto the sheared rivets on the belly pan - these were both our weak points - once found, repaired and sealed it only took a nights trapping to nail all of the critters (3 of them). As a precaution we now maintain a set trapline over winter when it is being stored - and part of the spring/fall to do list includes checking the underbelly.
Good Luck.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 11-24-2009, 08:50 AM   #11
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
3.b.m.
What is it with mice and the number 3 ?
Got three in a large glue trap a few days ago...and not any more since
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-24-2009, 09:07 AM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I deployed a 'trap' like this 2 mos. ago. I had just finished mopping the floor one evening and left the bucket of water next to the Honda gen which was against the dinette seat. In the morning there was a drowned mouse in the bucket.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-24-2009, 12:42 PM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Neil, we used to set up the bucket trap in the core shed at the Tonkin Springs gold mine, worked pretty good. Used peanut butter for bait on the ruler.
I always wondered why I save the round lemonade can tops other than for target practice. You probably noticed I'm using them for fenderwashers riveting the belly pan on, sealing those leaks. I still don't dare leave the Silver Dragon up on the plain for any time, the rats up there seem to morph through solid walls.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 11-24-2009, 10:46 PM   #14
FreshAir's Avatar
1966 24' Tradewind
My 'trap' bucket was unintentional. No bait but the little feller took the dive anyway. It did get me thinking though. We haven't had a real problem with mice until I found evidence in the convertible a couple of months ago. Hmmmm, I guess the ragtop is getting a bucket too!
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 11-25-2009, 07:31 AM   #15
pinktrailer's Avatar
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
"BOUNCE" 'em out!!
I find that distributing the biggest box of "Bounce" sheets (the worst smelling that I can find) in all of the lower cabinets, and around the upholstery does wonders for keeping them out!! I do it every fall. {It keeps me out too! I'll never understand how people can use them in their dryers.}
pinktrailer is offline   Reply With Quote
Old 11-25-2009, 08:06 AM   #16
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Neil.
Hey Neil..
First the airstream.. now the convertible... Kinda you bucket list huh...
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-25-2009, 09:18 AM   #17
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I just pulled the Safari out of its garage (to house Thanksgiving company) and found the telltale signs: poop and eaten poison pellets. As I was backing up to park I saw one dive out and run for cover in a stone wall. The cats have obviously gotten lazy.
Old 11-25-2009, 12:19 PM   #18
2005 31' Classic
Gretna , Nebraska
Baits - D-Con
My experience with D-Con is that the mouse(es) eat a dose of it and crawl into some remote part of the trailer and die -- AND STINK FOREVER. Especially on a humid day.
I got rid of a nice '70 Overlander because of this.
Dwight
16595 is offline   Reply With Quote
Old 11-27-2009, 02:51 PM   #19
Dan@LED4RV's Avatar
Denton , North Carolina
One more thing I have seen that worked, is filling the toilet bowl half way with freeze ban (the pink stuff), provided your bowl holds water, and leave the lid up. It is either the sweat smell or they get thirsty one which causes them to drowned their selves. :-)
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 11-27-2009, 03:56 PM   #20
Wayne&Sam's Avatar
Images: 21
Dwight
I've never had that problem. They tend to want water after eating the stuff and they go outside to find it, then croak.
Mice B gone ! Robbie R. Off Topic Forum 12 08-16-2010 04:39 PM
Mice!! Help! dreamer60 General Repair Forum 30 08-07-2009 06:12 PM
Mice not2tacky Plumbing - Systems & Fixtures 4 03-01-2009 04:46 PM
Of Mice and Me jmellana Member Introductions 7 08-16-2007 08:23 PM
Mice !! silverlassie General Repair Forum 40 04-04-2004 02:07 PM
