Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-21-2017, 03:11 AM   #1
Naples , Florida
Magnum MMS Series Inverter Error Message
Hi, I recently bought a 2016 Interstate EXT and am not getting power from the inverter side of the unit (Circuit 4). The house batteries had power after I ran the engine, but seemed to deplete quickly, even when I was plugged into shore power.
I replaced the batteries and thought that would solve the problem. It has not.
The Magnum inverter remote control display shows the error message "Fault! No Comm" and the red light is light. I've followed the owners manual's advice and reset the remote display. That did not fix the problem.
Can anyone suggest what else I can try? I am currently in Reno, NV and there is not an Airstream dealer here.
Thank you.
Harmantick is offline   Reply With Quote
Old 03-21-2022, 04:03 PM   #2
Mico , TX
Magnum Inverter MMS Error Code Fault: No Comm
Did you ever resolve this issue? I have the identical problem.
mg2sio4 is offline   Reply With Quote
Old 03-27-2022, 10:23 PM   #3
Mico , TX
2016 Interstate EXT - Magnum MMS Inverter Error Message
I had the exact same problem and troubleshooting results as described by Harmantick in his post.
With a volt meter, I discovered the coach batteries had 12+ volts on the brass battery connectors, but zero or virtually no voltage detected on the battery cable connector right at the battery. I removed the battery cables, thoroughly wire-brushed and cleaned the cable connectors (they didn't even look very dirty or corroded), added electrical conductor lubricant and re-installed. Problem resolved!
This was a lucky find and fix. I'm posting hoping to help someone else with this challenging issue.
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Magnum MMS-1012 inverter/charger lewster Airstream Classifieds 0 03-31-2016 06:42 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Inverter upgrades Support Admin Airstream Classifieds 0 09-23-2013 12:28 PM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
