Old 01-31-2014, 11:35 AM   #1
2008 23' Safari SE
west islip , New York
Lightbulb Lights flicker
I have a 2008 safari and the interior lights flicker and dim when more then one light is on.
kathy149 is offline   Reply With Quote
Old 01-31-2014, 11:38 AM   #2
SteveH's Avatar
Common Sense , Texas
You most likely have an intermittent, or loose battery connection between the power distribution panel and the converter/batteries. This could be on the positive side, or the ground side, and will take some research and testing to find.
Welcome to the forum.
Regards,
Steve
Old 01-31-2014, 11:45 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
SteveH's recommendation is the right place to start, check that all of the connections are secure and clean between the batteries and the fuse block.
If you find that the connections are all good, the next place to look is the state of the batteries and the converter. If your batteries are original, or even from 2010 or 2011 they may not be in good shape (especially if the trailer has been plugged in a lot with the original converter.) Also, the converter may be having issues. Measure the converter's output voltage and if you can, take the batteries to a shop that has a battery load/charge tester (auto parts stores often have these.) If you're not familiar with the battery removal process, be sure to unplug the trailer and to isolate the battery cables for the first battery while disconnecting the 2nd (assuming you have 2).
There are several possible causes of this symptom. For example, I replaced a converter that charged the batteries well enough, but when it should have been in "float" mode it would vary the output voltage every minute or so and cause noticeable flickering in the lights that annoyed me.
David
Old 01-31-2014, 01:47 PM   #4
SteveH's Avatar
I would add just one more thing after thinking about it a while. You don't mention but if this is the only electrical intermittent you have, and as a for instance, if the water pump and everything else works as normal, I'd check the wiring at the circuit breakers for that specific light power circuit.
Good luck.
Regards,
Steve
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
