Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 05-26-2004, 09:42 PM   #15
mandolindave's Avatar
Profile:
Has it occured to any of you to try cold fusion ?
mandolindave is offline   Reply With Quote
Old 05-27-2004, 05:53 AM   #16
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Go Bio. 500 mices in those little cages hooked up to a pulley system. Give the cat something to do while you're at happy hour.
Prehaps your lifts are defective. When correct you should end up needing to push the bed down.
Let those who can play, let those who cann't watch....
Over59 is offline   Reply With Quote
Old 05-27-2004, 11:32 AM   #17
Profile:  1984 31' Excella
Santa Barbara , California
King Size Bed....
Keeping it simple is the right approach. A winch approach would use tremendous force if kept totally below the bed. I weighed the bed and it approaches 100lbs (on the edge) at the hallway entrance side with the other side hinged. Will be going with stronger pistons as this keeps the design simple and less space used under the bed. Thanks to all for the conversation.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 05-27-2004, 02:12 PM   #18
Over59's Avatar
1968 17' Caravel
Images: 37
You may want to attach the base end a few inches lower to get it a better angle of attack. That way some of the force will be up rather than toward the foot of the bed.
If it requires 100 lbs at the end it will require 200lbs in the middle. I think those ratings on the pistons are in the vertical. You need to get out your trig book to figure the force at your starting angle to know if it offsets the weight at that point. Who said you wouldn't need this after high school.
Old 05-27-2004, 05:51 PM   #19
It's all in the angle....
Paul, you are correct. I have come to a similar conclusion on the angle and location of the base of the piston. I had a horizontal start before...now I know why my back went out with the 100 pound starting weight before the piston lift vector begins to do any good. (Those free body diagrams from mechanical engineering class weren't a waste either.) It is looking like 2 gas pistons, in the 100 lb. to 150 lb. class depending on a mid-frame mounting location and angle. I am leaning towards a much more vertical implementation if the cyclinder and stroke measurements of the pistons allow this with respect to the depth below the bed for attachments (14 inches max.)
By the way, the Suspa.com website gives an application sheet that asks for the required input data so they can work out all the trig functions, lift versus weight, etc. and then allows them to select the correct size and strength of gas pistons they manufacture.
Mark
AIR No. 2375
Old 05-28-2004, 01:30 PM   #20
Profile:  1973 31' Sovereign
Portland , Oregon
Question Garage door springs?
Just a thought...
It occurs to me that you could also use something like garage door springs instead of an electric winch. Your king size bed is close to 7' long. If you had brakets near the hinge like in the drawing I furnished they would probably be something like 1' long. Put one on each side of the bed and that would be something like 350 lbs of spring needed on each side. Would garage door springs be a lot cheaper than the struts? I don't know...
Malcolm
malconium is offline   Reply With Quote
Old 05-28-2004, 02:56 PM   #21
Over59's Avatar
1968 17' Caravel
Images: 37
Now this is a solution worthy of an Airstream
http://www.suspa-inc.com/index.htm
Old 05-29-2004, 10:55 PM   #22
Gas Piston Springs
Found a website where you can order gas pistons online with a credit card: www.mcmaster.com. This website is very effecient!
Have calculated that two 150 lb. gas pistons about 33 inches long with a stroke of 16 inches and mounted on the floor for a better angle of attack (>45 degrees starting angle) should work when attached midway down the bed frame.
I will report back when they are installed.....
Mark
AIR No. 2375
Old 02-27-2005, 09:30 AM   #23
Over59's Avatar
1968 17' Caravel
Images: 37
Thanks Mark. That has to be one of the best websites ever. Found the pistons I needed, and the hose.
How need the lift work out?
Old 02-27-2005, 10:27 AM   #24
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Electric tounge Jack at a angle closer to the hinge point. Cheap and easy to find. Little bit of brackets to fabricate but no big deal. Remote the switch. leave and acess opening where you could reach in and pull a disconnect pin at the bottom pivot if it ever failed.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-28-2005, 05:33 PM   #25
Portland , Oregon
Over59,
This does look like a great source. They have almost too much stuff. What category did you look under for the pistons you found?
Malcolm
Old 02-28-2005, 05:47 PM   #26
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Angry Low Tech
Why not just use a pair of hood hinges off, say, a 1984 Chevy pickup?
Why does it have to have two motors, twelve pulleys, a mile of rope, and a threaded rod? The simpler the better...
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 02-28-2005, 06:37 PM   #27
Gas Pistons
Originally Posted by malconium
Over59,
Malcolm
Malcolm:
Look under gas pistons or the brand name SUSPA. There are many varieties of end connectors also.
Mark
AIR No. 2375
Old 02-28-2005, 09:37 PM   #28
Portland , Oregon
The more exact category appears to be "gas lifts" or "gas springs" and there sure are a lot of possibles. I will have to take a closer look when I get a bit nearer to having a place for a bed.
Malcolm
Pingbacks are On
Twin Beds to Full Bed, A success story smily General Interior Topics 17 09-22-2006 08:18 AM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
Twin bed standard sheet? TomW General Interior Topics 5 03-09-2004 02:00 PM
Airstream twin Bed solutions briandeacon General Interior Topics 5 01-22-2004 10:31 AM
Bed Size 87MH Our Community 0 12-11-2003 09:56 AM
SEO by vBSEO 3.1.0
