Old 04-20-2009, 08:54 AM   #1
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Kitchen Base Cabinet
Subject: 1971 27' overlander. All original interior. The base cabinet that carries the range and sink is separating from the wall. There is a channel fastened to the wall, near the door,that the end panel fits into. The panel has slipped out of that. Any suggestions for a fix?
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 04-20-2009, 09:19 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Inside that channel are little clips with "teeth" that are supposed to grab the panel. I suppose the easiest fix would be to shove the panel in as tight as you can get it, and then drill several 1/8" holes through channel and panel, and put some extra long pop-rivets through the whole sandwich. (pop-rivets come in different lengths to accomodate different thicknesses of what you're riveting) You may also be able to get at it from the inside, and figure out some hidden way to re-attach that panel to the wall. Good luck- tim
tphan is offline   Reply With Quote
Old 04-20-2009, 09:51 AM   #3
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Thanks Tim, havn't given it a try yet. Thougth I would confer with the experts first! Like to fix it before selling it. I want to upgrade to more trouble!!
Base Camper? To be or not to be... Friday Base Camp 19 08-16-2009 03:48 PM
kitchen cabinet question tsprc 1959-69 Tradewind 8 12-14-2008 07:44 PM
Nutone base... Auretrvr Nu-Tone Appliances & Central Vac System 1 05-04-2007 11:42 PM
Bargman 99 Base Number99 Lights - Interior & Exterior 1 08-08-2005 02:44 PM
