11-25-2014, 05:51 PM
Austin
Kilz
I bought some Kilz Complete which is their oil based interior/exterior primer... would there be a problem with me using it on the interior aluminum walls? Someone said that they didn't think I should use it, that I should get a auto primer.
11-25-2014, 06:10 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Hey Trix,
I used Kilz, applied with a roller and an overcoat of interior latex. It's been five years now and have not had any problems. Looks good and wipes down easily.
Tim
11-25-2014, 06:13 PM
Austin
Originally Posted by Beaker63
Hey Trix,
Tim
That's what I like to hear. I was planning on doing the same thing. Do you remember which Kilz primer you used... was it one of their water based or was it their oil based?
11-25-2014, 06:40 PM
1964 17' Bambi II
Schererville
, Indiana
I used Kilz oil based primer on my aluminum walls. Worked well & covered the previous zolatone perfectly. I'd use it again.
Becky
1964 Bambi II
1988 Avion 32S
11-25-2014, 06:48 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Trix
I used the oil base. Applied with a roller. You will need a short roller for the curved end caps.
Tim
11-25-2014, 07:09 PM
Austin
Did either one of you use it over the bare metal also? My trailer is completely gutted so there are some unpainted metal areas where there were cabinets and sofa, etc.
11-25-2014, 07:11 PM
Broadway
, North Carolina
I highly recommend a new water based urethane primer - STIX. The stuff sicks to just about anything including plastic, pvc, matal and glass.
Ace Hardware and Town & Country sell it around here.
Stix® Waterborne Bonding Primer SXA-110, Primer
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
11-26-2014, 06:24 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Hey Trix,
Our trailer was completely gutted too. I had filled unwanted openings and rivet holes with automotive body filler then sanded the patch smooth. At this point some aluminum was exposed with the original Zolatone and I painted over all of it with oil based Kilz. It's still stricken.
Tim
11-26-2014, 07:03 PM
1964 17' Bambi II
Schererville
, Indiana
The only place my paint didn't stick was a new piece of aluminum that I forgot to prime with Kilz. Prime your new aluminum!
Becky
1964 Bambi II
1988 Avion 32S
11-26-2014, 07:20 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I would sand any bare aluminum. No finer than 400, and/or a purple scuff pad.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Kilz original
Joeymoran01 |
Interior Restoration Forum |
8 |
09-29-2014 09:48 AM |
Kilz Original
Joeymoran01 |
All Argosy Trailers |
3 |
08-17-2014 03:06 PM |
