Old 12-02-2002, 02:02 PM   #1
keeping the inside dry during storage
to go with the other thread about storage, how to you keep the inside dry while in storage?
not from leaks, just from moist air ?
is there anything you can put inside that will suck up the moisture ?
I have seen cars that were in storage and the inside turned green from what I would think was mold
again thanks for your advise
oldvws is offline   Reply With Quote
Old 12-02-2002, 02:34 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I keep mine at home. So what I try and do is go inside several times a week, open the vents and windows up, weather permitting. Sometimes I'll fire up the furnace and watch some TV for an hour or two during the evening.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-02-2002, 03:57 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
if there is no access to electric hook up for a dehumidifier , I would look into "damp rid" sold at wal mart or home depot to helpo soak up some of the moisture. Venting the inside will help also, but having lived in a salty-air near the ocean environ myself, I know it is a challenge. I also think you will benefit from a good wax coat on the outside- and possibly a cover for your trailer to prevent the outside sea air corrosion.
Inside Storage cedarfield On The Road... 6 03-06-2004 03:36 PM
Storage fees cosmotini Our Community 28 02-04-2004 03:24 PM
Short-term storage in central FL? rluhr Our Community 9 12-02-2003 10:36 PM
Long term storage accomodations 85MH325 Our Community 32 11-02-2003 10:52 PM
Dry weight variances Moonshot On The Road... 1 09-11-2003 09:06 PM
