Old 08-03-2016, 10:35 PM   #1
1976 Argosy 26
Henderson , Kentucky
Images: 14
J Trim installation technique?- 76 Argosy 26
As many know the vinyl J trim around front window and along front interior panels in 76 Argosy can/has dried, cracked and at points fell off. Any bump or contact can split. So, new Vinyl J trim ordered and need pointers on best technique for replacement? Do you require rivet removal, or can you work onto panel edge as you remove old trim, or use light pry pressure to ease open panel gap? My impression is rivets hold too tight and I do not want to damage panel. So before getting into this job I need directions. I did not find prior thread but know this is frequent issue for older models, and thanks in advance.
Ky76Argosy is offline   Reply With Quote
Old 08-07-2016, 03:48 PM   #2
1976 Argosy 26
Images: 14
how to install interior J trim at windows?
Really need someone to give insight on installing that small interior panel trim called j trim found around front window and interior front wall panels to finish edges??
Old 08-07-2016, 04:28 PM   #3
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I'm needing to replace it in mine as well. When I do mine I will drill the rivets, insert the new trim, drill thru at existing rivet holes and re rivet. The original rivets have held up the existing but broken j trim for the last 43 years is kinda my way thinking on it. Hope this helps.
1973Argosy is offline   Reply With Quote
New Partitions - What's the best technique? muddy_hollow Upholstery, Blinds, Walls & Interior Finishes 3 06-25-2008 04:59 AM
having trouble with my cyclo technique greenrig Cleaning, Stripping & Polishing 21 04-09-2008 11:33 AM
Final Floor Replacement Technique JohnG Repairing/Replacing Floor &/or Frame 46 01-15-2006 04:43 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 10:09 PM
Questions on riveting technique 74Tradewind Ribs, Skins & Rivets 6 05-24-2002 10:45 PM
