Old 08-23-2007, 02:20 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
J trim
Hello everyone... Has anyone replaced their J trim around the wraparound window in the front..??? We have an Argosy and need some hints for getting it to curve around the rounded corners.. Have cut into the back like it was previously done.. but the j trim is stiff and difficult to bend.. thinking of heating it.. any suggestions would be appreciated...
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-23-2007, 02:33 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi - I've done this and it works out very easily. With sidecutters nip the long side every inch or so -- a little further apart in areas of lesser curve. Temporarily remove rivets, insert the J trim, drill thru the J trim and re-insert new pop rivets. I used J trim that appeared very OEM -- got it from Tucson's Oasis RV Airstream dealer.
5 meter Langford Nahanni
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Trim Paint Melissa Hamilton Clearcoat, Exterior Paint & Trim 3 07-17-2004 02:54 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
