Old 07-26-2009, 10:19 AM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Is the trim piece between the endcaps and the ceiling still available?
I've been stripping off all the vinyl from the '75's interior and needed to drill out the rivets that attached the endcap to the aluminun ceiling. There is a plastic trim piece that has chunks missing from it and just looks ugly and I would like to replace it.
The trim piece is about and 1" wide, sliding between the ceiling material and the endcap and has a visible lip that covers up the end of the aluminum so you don't see the sawn edge.
Ron
ronstory is offline   Reply With Quote
Old 07-26-2009, 11:12 AM   #2
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I used a white trim available at Lowe's for about $2 per 8' piece. I cut notches out for the rivet shanks and slid it in place. (I used a putty knife to create a bit of space when riveting the ceiling back in place to make installing the trim easier.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is online now   Reply With Quote
Old 07-26-2009, 11:20 AM   #3
That was replaced by a metal "J" trim, that I think is still available.
Old 07-26-2009, 11:38 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Hey, Ron: what was that "trim" originally meant for? (so one might find it in the aisles of Lowe's...).
Mine is actually all in one piece...but its all yellowed and icky looking. I might try that "retro-bright" treatment on it, and see how it does.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-26-2009, 11:43 AM   #5
That "J" trim was to shield the sharp edges of the vinylclad from your fingers, and to add to the finished look of the interior.
It yellowed in time, and became very brittle.
It's about 1 inch wide.
Old 07-26-2009, 11:49 AM   #6
aluminauti
whitelight's Avatar
Where we , Park it!
J Molding
Chuck,
This trim is called "J" molding - don't think that retro brite will work as the plastic is brittle & shatters with any movement.
Basically, this trim is used to finish raw metal edges.
Check with some of the Airstream vendors - I know we've purchased 12' lengths from Inland RV in an off-white color. The width was such that we didn't have to notch out the molding for the rivet shanks.
whitelight is offline   Reply With Quote
Old 08-10-2009, 09:23 AM   #7
Chattanooga , 37415
Still looking for trim
Hi gang, I have been reading these posts because I am looking for a c-shaped type of trim that covers an opposite c-shape piece of metal in my 1075 Argosy. These trim pieces snap on and there is a lot of talk about j-trim but this is not quite what I am looking for. This trim is plastic and is roughly 9/16' wide and fits on to a track with a u or c shaped piece. Any help would be much appreciated!
ARRRRRRgosy is offline   Reply With Quote
Old 08-10-2009, 10:47 PM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Do you have a pic?
Ron
Old 08-10-2009, 10:47 PM   #9
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Oh... and welcome to the forums.
Ron
Old 08-13-2009, 09:22 AM   #10
Chattanooga , 37415
Thanks Ron
Thanks for the welcome Ron. here are two photos, one of the track the trim rides on and one image of an old piece of trim itself. Thanks again for the help!
ID:	85311   Click image for larger version
I need a piece of belt-line trim... malconium Clearcoat, Exterior Paint & Trim 14 09-28-2017 11:01 AM
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 5 06-22-2009 07:54 PM
When did AS convert to plastic ceiling endcaps? ronstory Upholstery, Blinds, Walls & Interior Finishes 7 07-19-2008 10:34 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
