Old 06-04-2008, 06:49 PM   #1
West Islip , New York
Question inverter plug
I have a 2008 23ft safari. It has two lighter plugs for the inverter to go in. The one in the front cabin is not round. I called my airstream dealer and he did not have an answer for me. I need to know how to use the inverter that plugs in (light a lighter plug in a car) which is not round. I had a 25 in flat screan installed and can not use it when I dry camp at Montauk NY. Anyone have an answer? Rob
katsix is offline   Reply With Quote
Old 06-04-2008, 07:40 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The quick answer is to use the 12v plug that is not distorted until you can get the other one taken care of. I'm guessing the "not round" plug is obloid, and if so, it shouldn't be that way.
Old 06-04-2008, 08:55 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
There were some 12V receptacles installed that are undersize defective manufacture. If you got one or more you'll need to replace them-they dont fit anything
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-20-2008, 01:36 PM   #4
It is the power booster inverter plug. It has six sides and I can not find an inverter to fit into it. Any Ideas??????? Katsix
Old 06-20-2008, 02:34 PM   #5
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Hard wiring it is probably a better solution anyway........
I tapped in behind the fridge.
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-19-2007 11:23 PM
What is an INVERTER woodedareas Electrical - Systems, Generators, Batteries & Solar 7 11-28-2006 11:37 AM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 09:25 PM
inverter mlmarch Mechanics Corner - Engines, Transmission & More... 2 11-15-2004 10:36 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
