Old 12-12-2011, 10:08 AM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Interior walls sweating in cold
A friend of mine when camping in cold weather reports the walls of his trailer sweat
They are all aluminum.
He has a flying cloud 28'. What can he do and is this common?
'77 Sovereign Intl 31' CB
Old 12-12-2011, 10:27 AM   #2
2002 19' Bambi
Lafayette , California
It is simply condensation from the humidity in the trailer and occurs more easily with the bare aluminum walls in comparison with walls covered in some fashion.
The easiest solution is good ventilation all the time. Even in the coldest weather, we have one roof vent and one window slightly open. With the heat on, that moves fresh (and dry) outside air in and lets humid inside air out. The humidity inside the trailer comes not only from cooking and such, but also from the occupants themselves. From breathing, for example.
Tim
Tim A. is offline   Reply With Quote
Old 12-12-2011, 10:29 AM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Do you think a small dehumidifier would help him, perhaps draining into sink?
Old 12-12-2011, 11:11 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If the walls are sweating, the windows must be dripping. They must control the moisture inside or risk damage to their unit.
There are two ways to control moisture and both are needed. Prevention and ventilation.
Use the range hood fan and limit cooking that releases large amounts of moisture (boiling). Wipe down the shower after use and hang towels outside. The furnace seems to be a dryer heat source than electric heaters or heat pump, I don't know why.
Set the temperature at lower levels, especially at night.
Open the vents, use the range hood fan, as needed to ventilate.
The number of occupants also matters a great deal. There simply is not enough interior volume to live the same way you might in a house.
doug k
Old 12-12-2011, 12:20 PM   #5
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Tim's advice is good. Heat on but ceiling vent open a little to move the air about. There are ways of reducing condensation but you'll never eliminate it completely in cold weather.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 12-12-2011, 12:25 PM   #6
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
And you'd be surprised at how much moisture simply breathing puts into the air! A night in a small tent with all the windows closed in the wintertime can mean a soggy sleeping bag simply from breathing - ventilation is the key!
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 12-12-2011, 12:38 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yes, a small dehumidifier will help greatly.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-12-2011, 12:39 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A dehumidifier on a timer to operate when the trailer is empty will make a great heater too - if the unit takes 500 or 600 watts to run it will give off at least 1000 or 1200 watts worth of heat from the refrigerant phase change. Think heat pump with benefits, but usually too noisy to live with.
If there is that much condensation coming out be careful with bedding, outdoors clothing and shoes - once they get that 'damp' feeling it takes ~75% more energy to warm them up and feel comfortable than if they weren't.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 12-12-2011, 03:51 PM   #9
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
All Good Advice...
but let me add one more thing.
In building science we refer to the "first condensing surface."
In a house (or an Airstream) this will be an uninsulated wall or a window the outside suface of which is exposed to the cold outside temperature.
So, you story tells us a couple things:
1. Your friend's Airstream is not well insulated.
2. Your friend is cooking too much pasta (just kidding... sorta)
In a typical, semi-well insulated Airstream, moisture laden air will pass through the seams of the interior skin, pass through the porous insulation, and whamo hit the first condensing surface, the inside surface of the outside skin!
The moisture condenses and runs down the inside surface of the outside skin where it soaks into the subfloor and causes the famous Airstream floor rot. So, not every Airstream with a rotten floor necessarily has leaks, though most do.
Inside moisture control is critical as discussed in the earlier posts. If we cook pasta we must vent the steam outside through the exhaust fan. If we take a shower, we must run the exhaust fan. Even heating the water in a tea kettle generates moist air.
Since most Airstreams are used for summer recreation, this is not usually an issue since they are parked, unused through the cold winter months.
It becomes a huge issue when folks try to live in their Airstreams in the winter in places like New York. This is why Airstreams that have been lived in year round may have "issues" shall we say.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 12-12-2011, 03:58 PM   #10
dznf0g's Avatar
Oswego , Illinois
In a typical, well insulated Airstream, moisture laden air will pass through the seams of the interior skin, pass through the porous insulation, and whamo hit the first condensing surface, the inside surface of the outside skin!
OK,
1) NONE of them are insulated well!
2) I like Pasta!
Get a 25 litre compressor style dehumidifer. (the smallest I can find)
Do not waste your time and money on the little "mini" ones....if you like pasta or have more than one person living in the AS.
-Rich-
Old 12-12-2011, 04:16 PM   #11
Alumaholic's Avatar
Images: 36
dznf0g is Right, of Course
Originally Posted by dznf0g View Post
OK,
2) I like Pasta!
To describe any Airstream as well insulated is like describing a well-washed garbage truck.
I have edited my post.
It now says "semi-well insulated Airstream."
Ken L
Old 12-12-2011, 04:24 PM   #12
dznf0g's Avatar
Oswego , Illinois
"No worries, Mate....."
You guys in the SW probably haven't really had to deal with a real "sweater", like I have never had a "my 13.5 A/C doesn't keep my 30'er cold".....
-Rich-
Old 12-22-2011, 12:10 PM   #13
BrandonJenna's Avatar
2012 27' FB International
Corvallis , Oregon
Very informative. My wife and I have been living in ours and we have had serious sweating going on initially on the windows, but as I concluded and you have confirmed.... The condensing of the moisture on the inside of the outer wall has been mixing with a water-based glue used in our 2012 AS and leaking the sticky solution down through the frame of the window screen. At first I thought we had a bad leak (which was also true) but now that it has been repaired and it hasn't been raining, the leaking has returned.
Thank you for your post. My wife will crack a window, leave open a vent and purchased a compressor style dehumidifier.
Any recommendations for dehumidifiers that are small and amazing?
BrandonJenna is offline   Reply With Quote
Old 12-22-2011, 12:59 PM   #14
dznf0g's Avatar
Oswego , Illinois
I've done a lot of online shopping and I think I am going to do these:
NewAir AD-250 25 Pint Portable Room Dehumidifier With Automatic Shut-Off - FREE GROUND SHIPPING!
It's the smallest I have found, dimensionally. It gets great reviews from a lot of boaters and RVers. However, it does not have a humidistat, meaning it is always on.
So , I'll get one of these too.
Dayton 1UHG2 Dehumidifier Control, Plug In 120 V
There are other 25 pint units out there, but this one is quite a bit smaller and a lot lighter.
-Rich-
Old 12-22-2011, 01:39 PM   #15
Central , Mississippi
I added a thru floor/belly pan drain tube and attached it to the drain port of our de-humidifier...let it run!
Crackin' a vent 'to let in dry air' doesn't work so well here in the South East
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 12-22-2011, 04:45 PM   #16
jdalrymple's Avatar
Jay , Oklahoma
Yeah, no need to crack a vent with a dehumidifier running.
Jeff & Cindy
'91 350 LE MH
Old 01-05-2012, 01:02 PM   #17
Corvallis , Oregon
Dznf0g,
I purchased the newair dehumidifier you mentioned and it works very well! The size is excellent for our AS and it pulls moisture our way better than chemical methods. I have noticed within a weeks time it has gotten louder be it fan and compressor. Not unbearable though.
Additionally, if I run a 750 watt electric heater while the dehumidifier is running, I notice the power to all of the outlets will shut off for a few minutes without tripping any breakers. I can reset the main or wait a few minutes and it will come back on. Is this bad tor the electrical system? Since discovering this I have been afraid to run any other heater than the furnace while the dehumidifier is running.
Advice?
Old 01-05-2012, 01:33 PM   #18
dznf0g's Avatar
Oswego , Illinois
Dznf0g,
Advice?
Strange behavior. The dehumidifier is 190 watts only so I don't know. If the circuits are overloaded, a breaker should trip. I'm having trouble visualizing anything else. Maybe someone else has experienced this.
Would you describe the increase in noise as a plastic buzz or vibration? Some reviewers commented on increased noise due to plastic case starting to buzz. They took the case off and used tape and foam to keep the plastic parts from "itching" and they quieted right down. Mine hasn't demonstrated the increased noise yet, but I may get bored and go ahead and isolate the case.
-Rich-
Old 01-05-2012, 11:49 PM   #19
Corvallis , Oregon
Well I tested it with my "Kill A Watt P3" and I found that on average, while the compressor is running it is pushing 395 watts however just the fan is less than 20 watts. I used the "Kill A Watt" tester when I first got the dehumidifier and it was peaking over 700 watts so I am wondering what was going on then compared to now. I am watching it to see if it does it again or if it was simply a break-in period.
See More on the Kill A Watt:
http://www.p3international.com/manuals/p4400_manual.pdf
http://www.p3international.com/brochures/P4400.pdf
ID:	148357   Click image for larger version
Old 01-06-2012, 09:26 AM   #20
dznf0g's Avatar
Oswego , Illinois
Wow! The label on the unit behind the water container says 190W. I'm gonna pull mine out and measure it. Be back shortly.
-Rich-
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 08:25 PM
Front Bed Wall Coverings? It was cold! robwok Upholstery, Blinds, Walls & Interior Finishes 12 11-02-2011 01:40 PM
1967 fridge gets cold on 110V, but not on gas aircooled4 Refrigerators 15 10-26-2011 08:58 PM
How long will the Refrigerator stay cold? bspelce On The Road... 48 08-25-2011 06:29 PM
How about stealing cold from the freezer? mikeandnora Refrigerators 2 07-27-2011 01:13 PM
