Old 01-22-2012, 07:00 PM   #57
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Originally Posted by BrandonJenna
This looks very appealing: HyperVent Marine - Product Information
It is a breathable material with allows air to move between the mattress and the wood underneath. Take a look!
-Brandon
Oooh, rock and roll, I may go that route! Bless you my child!
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 01-22-2012, 07:06 PM   #58
dznf0g's Avatar
Oswego , Illinois
-Brandon
Nice find! Has anyone used this? How does it hold up over time? Does it compress over time?
I bookmarked this one....thanks, Brandon.
-Rich-
Old 01-22-2012, 07:33 PM   #59
BrandonJenna's Avatar
2012 27' FB International
Corvallis , Oregon
I have no idea but I ordered 10 feet of it (by 39 inches) which I will cut into two pieces and lay perpendicular atop the wood.
I will let you know what I think a little later.
BrandonJenna is offline   Reply With Quote
Old 01-22-2012, 07:36 PM   #60
dznf0g's Avatar
Oswego , Illinois
Don't they sell the same stuff for some construction purpose over at the big box home improvement store only without the smooth covering?
Edit: I just remembered where I saw it. It was on Holmes on Homes (or whatever it is called) They use it between decorative stone facade and the concrete (or wood) substrate so water won't freeze and crack the stone away from the wall. Lets water drain and air circulate. Hmmmmm, wonder if it woud be cheaper? Would be easy to attach fabric to it to protect the mattress.
-Rich-
Old 01-28-2012, 02:11 PM   #61
Corvallis , Oregon
I received the hypervent product and installed it moments ago, take a look:
Prior to installing the hypervent I ran heaters on the mattress and damp wood until I was convinced it was dry enough (all morning). I then used kitchen-aid scissors to cut the hypervent to fit (very easy to cut but I recommend wearing gloves).
I will give this a couple of weeks before I pull it up and take a look. Already I do notice it is easier to slide the mattress around atop of the wood (not necessarily a good thing) and the sheets tend to catch on the curly plastic when making the bed.
Regardless I am excited and am hopeful this will solve the issue.
-Brandon
Old 01-28-2012, 03:32 PM   #62
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
I wonder if putting down some that non slip shelving liner would help stop the mattress slipping around? Or a bit of double sided carpet tape?
Old 01-29-2012, 05:53 PM   #63
Central , Mississippi
I'm not saying that this was the solution for ME...
OR the solution for YOU...
but...
I know of someone who used this to solve a similar problem...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-30-2012, 10:55 PM   #64
Corvallis , Oregon
but...
Hahahahaha... I'll wait awhile, I only turned 29 last Friday
Old 01-30-2012, 11:13 PM   #65
Corvallis , Oregon
I noticed the screen needed cleaning but upon closer inspection, the unit needed to be defrosted.
Well, It may not be a good idea to run your New Air AD-250 on a non-stop basis. I thought the interval period would be sufficient enough to prevent freezing but it seems I was wrong. I believe this is after a solid-two-weeks of run time. I have it thawing inside the house, in the shower. The unit still pulled more moisture out of the air than I expected, despite this impediment.
-Brandon
Old 01-31-2012, 07:24 AM   #66
dznf0g's Avatar
Oswego , Illinois
That's one of the reasons why I got one of these as well.
Dayton 1UHG2 Dehumidifier Control, Plug In 120 V
Boy, I would've thought the sensor would have called for defrost before it got that frozen up. Hmmmmmmm.....
-Rich-
Old 02-26-2012, 10:42 AM   #67
Corvallis , Oregon
An update on the Hypervent! So far it has been an incredible improvement. BUT, since my wife and I full time in ours there seems to still be a slight moist feeling on the wood to the touch. Temperatures have been between 30 and 48 Fahrenheit over the last 2 months+. We keep the AS about 65 degrees. The hypervent has proven to keep us warmer and the wood cooler so as not to cause as much condensation. I did flip the hypervent over (opposite side pictured in the images I uploaded), this helped prevent the mattress from sliding when brushed up against.
If you have any questions, don't hesitate to ask.
-Brandon
Old 08-18-2012, 12:07 PM   #68
sierrafun's Avatar
Ladera Ranch , California
Brandon,
Thank you for taking the time to share all your "breaking-in" issues with us. It's been invaluable to us.
I'm writing because it's been almost 6 month's since you've posted the above update on the Hypervent and I am wondering how it has worked out for you? Did flipping it over help with some of the condensation that continued and also with helping to prevent the mattress from sliding?
We haven't purchased our 27FB yet but we are hoping to within two years.
Off topic here but just wondered:
1) How are you liking your floor plan choice?
2) Are you finding that you like the pano windows in the bedroom or would you consider adding the closets in there?
3) Does the outside storage next to the propane tanks get on your nerves or do you deal with it? The poor design of outside storage bothered my husband but perhaps it's not that big a deal?
Thanks for your advice :-)
sierrafun is offline   Reply With Quote
Old 08-20-2012, 02:19 PM   #69
Corvallis , Oregon
Great Day!
Flipping the Hypervent did help to reduce the slippage, I currently have the fabric side down against the wood. When I put the sheets on I wrap them under both the mattress and the Hypervent so as to not snag. There is absolutely no moisture build up most of the year, the coldest part of winter is much harder to prevent accumulation from happening but the Hypervent is a miracle!
We love our floor plan and wouldnít trade the bedroom panoramic windows for anything, even if the alternative is a little extra storage. For us, our own night stands are worth more than the closets that would otherwise replace them. You will realize just how much you love the panoramic windows the first time you take it out to a local that has a 360 stunning view. Itís amazing.
I especially like the FB because it letís us remain hitched up to my 1986 F-250 (which rides just slightly higher if not perfectly level) and have absolutely no decline towards our head. Of course this could be accomplished by also raising the jack while leaving it hitched but if you are just stopping in to sleep for a night and want to unpack as little as possible, this works. There are other reasons we love the FB too, the way the door lines up with my siblings homes & driveways, etc.
The outside storage does not bother me at all. I have never really experienced anything different on a trailer though. I am considering putting a toolbox in the back of my truck so I can easily access the gear I need to maintain our trailer. All we currently have under that front storage is outdoor carpet, mats, towing tools and locks, extra fuses, outdoor shower, extension cords, etc. All of which is easily accessed items. I keep my hiking shoes in there too.
Message, email or post if you have any other questions, would like to see some pictures or need advice! Take care.
-Brandon
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Front Bed Wall Coverings? It was cold! robwok Upholstery, Blinds, Walls & Interior Finishes 12 11-02-2011 12:40 PM
1967 fridge gets cold on 110V, but not on gas aircooled4 Refrigerators 15 10-26-2011 07:58 PM
How long will the Refrigerator stay cold? bspelce On The Road... 48 08-25-2011 05:29 PM
How about stealing cold from the freezer? mikeandnora Refrigerators 2 07-27-2011 12:13 PM
