Old 12-22-2011, 12:39 PM   #15
Central , Mississippi
I added a thru floor/belly pan drain tube and attached it to the drain port of our de-humidifier...let it run!
Crackin' a vent 'to let in dry air' doesn't work so well here in the South East
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-22-2011, 03:45 PM   #16
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yeah, no need to crack a vent with a dehumidifier running.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-05-2012, 12:02 PM   #17
BrandonJenna's Avatar
2012 27' FB International
Corvallis , Oregon
Dznf0g,
I purchased the newair dehumidifier you mentioned and it works very well! The size is excellent for our AS and it pulls moisture our way better than chemical methods. I have noticed within a weeks time it has gotten louder be it fan and compressor. Not unbearable though.
Additionally, if I run a 750 watt electric heater while the dehumidifier is running, I notice the power to all of the outlets will shut off for a few minutes without tripping any breakers. I can reset the main or wait a few minutes and it will come back on. Is this bad tor the electrical system? Since discovering this I have been afraid to run any other heater than the furnace while the dehumidifier is running.
Advice?
BrandonJenna is offline   Reply With Quote
Old 01-05-2012, 12:33 PM   #18
dznf0g's Avatar
Oswego , Illinois
Originally Posted by BrandonJenna View Post
Dznf0g,
Advice?
Strange behavior. The dehumidifier is 190 watts only so I don't know. If the circuits are overloaded, a breaker should trip. I'm having trouble visualizing anything else. Maybe someone else has experienced this.
Would you describe the increase in noise as a plastic buzz or vibration? Some reviewers commented on increased noise due to plastic case starting to buzz. They took the case off and used tape and foam to keep the plastic parts from "itching" and they quieted right down. Mine hasn't demonstrated the increased noise yet, but I may get bored and go ahead and isolate the case.
-Rich-
Old 01-05-2012, 10:49 PM   #19
Corvallis , Oregon
Well I tested it with my "Kill A Watt P3" and I found that on average, while the compressor is running it is pushing 395 watts however just the fan is less than 20 watts. I used the "Kill A Watt" tester when I first got the dehumidifier and it was peaking over 700 watts so I am wondering what was going on then compared to now. I am watching it to see if it does it again or if it was simply a break-in period.
See More on the Kill A Watt:
http://www.p3international.com/manuals/p4400_manual.pdf
http://www.p3international.com/brochures/P4400.pdf
ID:	148357   Click image for larger version
Old 01-06-2012, 08:26 AM   #20
dznf0g's Avatar
Oswego , Illinois
Wow! The label on the unit behind the water container says 190W. I'm gonna pull mine out and measure it. Be back shortly.
-Rich-
Old 01-06-2012, 08:52 AM   #21
dznf0g's Avatar
Oswego , Illinois
This is a pic of right after plugging it in. It actually started out at 200W but by the time I got the camera ready, it went up to 206W. Compressor driven devices have a tendency to rise in power need and consumption until full operating pressure is achieved in the freon system.
This is after about 10 minutes of running. It seemed to stabilize here. It is still running and I will only repost if it changes significantly.
I am concerned that yours is that high. It APPEARS to me there may be an obstruction in the freon line on the high side of the orifice. I am still totally unclear why you have that "brownout" scenerio. This high pressure possibility could also result in you noise issue. I'd call your vendor and explain your situation. Maybe point them here. See if you can exchange the unit.
-Rich-
Old 01-06-2012, 09:32 AM   #22
dznf0g's Avatar
Oswego , Illinois
OK, it settled in at 213 watts and never changed. I definitely think you have an obstruction ro binding motor or compressor. 700W peak and almost double while running.....something is wrong. Call the vendor ASAP. And I would unplug it.
-Rich-
Old 01-06-2012, 09:41 AM   #23
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
The major cause of the problem of condensation in an Airstream appears to be answered in this thread.
http://www.airforums.com/forums/f483...ml#post1090291
Old 01-06-2012, 11:01 AM   #24
dznf0g's Avatar
Oswego , Illinois
Wait! You do have model AD250, right? Reason I ask is there is no "fan only" setting. If your compressor is shutting off and coming back on, that's another indication of high "head" pressure.
-Rich-
Old 01-06-2012, 01:56 PM   #25
Corvallis , Oregon
Yes it is the model AD250. I haven't seen it peak to 700 or even reach 400 other than that one time but you are probably right, I should unplug it. Should I contact the manufacturer or the company I purchased it from online?
Old 01-06-2012, 02:09 PM   #26
dznf0g's Avatar
Oswego , Illinois
You've had it such a short time, I would call the vendor for an exchange and be firm in that request. If it was a year old I'd go to the mfr.
Who is the online vendor? Never hurts to let them know that we have been discussing them on the forum and their remedy will be seen by many who have a need for a compact dehumidifier and have the means to purchase. Get my drift?
-Rich-
Old 01-06-2012, 02:14 PM   #27
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Umnn - an oil slug of the refrigerant oil having separated out in a long unused and cold dehumidifier or even refrigerator can/will trip the compressors internal temperature limit switch or throw the supply circuit breaker. The compressor section gets staggered by trying to compress or pump out the oil when it is expecting a gas - a normal operating condition if its once every year or so.
Was the dehumidifier mechanisms at 70~F when you first powered it up? The internal freon plumbing is finely tuned to the usual household comfort temperatures for energy efficiency & economy - yes you can use it down to 35 to 40F once its warmed up but starting it cold after letting it sit for may show just what you observed.
Old 01-06-2012, 02:38 PM   #28
dznf0g's Avatar
Oswego , Illinois
Good point. I assumed this occurred during the constant running during the last week(s). Did I assume incorrectly?
1) When did you note the 700 W peak and 400W run? At first startup? Or after some extended running?
2) What is your wattage during "normal" operation?
3) Is the compressor turning on and off (fan only) during normal operation at room temperature?
-Rich-
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Front Bed Wall Coverings? It was cold! robwok Upholstery, Blinds, Walls & Interior Finishes 12 11-02-2011 12:40 PM
1967 fridge gets cold on 110V, but not on gas aircooled4 Refrigerators 15 10-26-2011 07:58 PM
How long will the Refrigerator stay cold? bspelce On The Road... 48 08-25-2011 05:29 PM
How about stealing cold from the freezer? mikeandnora Refrigerators 2 07-27-2011 12:13 PM
