Old 11-23-2014, 10:55 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
interior walls
My completed trailer ready to camp weighs 6500 lbs. (via scale ticket)
I figure the wood and the rest of my mods added about 1,200 pounds net to the trailer.
If I get to build another I think I might see how 1/8" plywood might work, that would save quite a bit of added weight.
I figure I used about 30 sheets of 1/4" plywood less waste, (counting my cabinets and fixtures) probably about 40 pounds a sheet for birch, a bit more for the oak.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-24-2014, 08:15 AM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks for that great info! Just speculation, the expansion of the aluminum may be similar to the wood so is not much of an issue.
That is more than "food for thought" that is a feast!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-24-2014, 09:42 AM   #17
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
I will be using 1/8" birch on mine, right over the wall skins, next spring. I did a test piece about two feet wide, full height (eight feet), oiled to a nice medium-dark finish, and it fits and looks just fine. Weight should not be an issue.
youngpeck is offline   Reply With Quote
Old 11-24-2014, 10:07 AM   #18
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
interior walls
Going to 1/8", I imagine you will save about five or six hundred pounds from what I did.
If I had it to do over, I would add a layer of 1/8" foam between the skins and the wood.
The thermal difference the wood alone makes is substantial, the foam would likely add even more insulation value.
Old 11-24-2014, 12:19 PM   #19
youngpeck's Avatar
1976 25' Caravanner
That's a lot of weight to save! The 4 x 8 1/8th-inch sheets are pretty light. I like the idea of a layer of foam. So what type of foam would you recommend?
Old 11-24-2014, 12:26 PM   #20
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The good thing about the old trailers is their lightness. Starting with a 5,000 pound trailer has its advantages when doing a project like this.
Even though I used 1/4" ply, my trailer is still a lot lighter than a new Airstream. I was actually shocked to see how heavy these trailers have become, but it kind of provides a guide on what kind of increase is acceptable.
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 87 10-12-2014 03:39 PM
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 10:18 AM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
removing interior walls: bad idea? pinkflamingoes General Interior Topics 45 07-14-2004 08:18 AM
1955 Flying Cloud Interior Walls Steph Upholstery, Blinds, Walls & Interior Finishes 6 01-12-2004 08:48 PM
