Old 05-12-2011, 06:19 PM   #1
chowman2011's Avatar
Leadville(for now) , Colorado
Interior Wall Structure Strip
I have one Interior Wall that previously had a structure strip screwed into the aluminum interior skin.....
The wall and strip are gone....
I am looking to rebuild this wall(which is part of a cabinet)...the other wall is 1/2" plywood tied tto the bathroom shower stall(cabinet between bathroom and bedroon area)....
Biggest Factor here: Replacement of the Structure strip(mounts to wall and portion of ceiling) and has mouting poiint for the intior wall...
Suggestions on a replacement? Only thing I have foune locally is a somwhat flexible shelving strip...but it has less than 1/8" sides to locate the interior wall....
This is for My '77 Silver Streak "Refurbish"....I know--not an AS but someday...
Any Ideas or Sources are Greatly Appreciated!!
Thanks!!
Logic, Reasoning and Cost Happening....All Part of the Visualization--Not a Rationalization...
chowman2011 is offline   Reply With Quote
Old 05-12-2011, 09:22 PM   #2
n8andm's Avatar
Minneapolis , Minnesota
If I understand correctly you might be able to use a French Cleat. Do you have a picture or a drawing?
_______________
/.:N8andM.in.MN:.\
|:Silver Streak Jet:|
n8andm is offline   Reply With Quote
Old 05-13-2011, 09:41 AM   #3
Originally, it was a 'gold' aluminum strip screwed into the side wall and up through the curved roof area. It had a 90degree that lipped over the wall section with a few mounting point to the wall.
Then with the floor strips and cabinet support pieces in place--a sturdy wall.
I am looking to replace this wall section (so I have the cabinet(shelf) space there)...
The dilemna is the curved section of the interior wall...most of the items I have found do not bend(to conform) to the curve.
I suppose I could just utilize some 90 degree aluminum for the straight section of wall in conjuction with a couple of interior fasteners for the curved section.
Ideally I would like to replace with an original type 'support brace'....hmmmm
To answer your idea...a french cleat isn't really the solution I am looking for in this application...
Thanks for Your Suggestion Though!!
I will think on this some more.....
Old 05-17-2011, 09:09 AM   #4
Rivet Attached link for a visual
Look at post #11 , Picture#4
http://www.airforums.com/forums/f417...ish-77204.html
This is where the structural strip and wall needs to go back in.
I have a tentative solution posted there also.
Cheers,
Christopher
interior, restoration, vintage kin, walls
Excella is full of Surprises! Mr & Mrs S 1993 Excella 1000 195 09-26-2014 10:41 PM
Strip & Polish 89 Excella 32' cjack99 Cleaning, Stripping & Polishing 14 04-06-2012 11:03 AM
Post Vinyl Wall Strip - How to buff? BrockLives Upholstery, Blinds, Walls & Interior Finishes 11 07-22-2011 12:31 PM
Caravelle Floor Structure overlander64 1980 Caravelle 3 03-28-2011 09:19 PM
Shower Seal Strip? FullTimin2HI Sinks, Showers & Toilets 1 03-17-2011 07:30 AM
