Old 02-13-2010, 04:56 PM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Interior Trim
In my 74 Argosy 26 it has this plastic trim tucked under the sharp edges of the aluminum interior skin where it meets the plastic dome on the ceiling. Anyone know where I can find something to replace it with. Also looking for new material to slide in the extruded aluminum trim pieces on the front dome and around the tub. It is 1 1/16" wide with a step on each edge. Any ideas on what I can use around the curved front windows for trim on the inside?
TG Twinkie is online now   Reply With Quote
Old 02-14-2010, 03:37 AM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi TG Twinkie;
The sheet edge trim can be purchased from Out of Doors Mart in NC. 1-866-636-2267. Insert for tub trim pending the style you want is another issue. First consider the fact that flat rigid insert will allow water to collect inside aluminum trim which eventually will mildew. Vinyl insert of proper width would seal the trim channel, but color choices are slim. Most RV supply houses will have a 3/4"- 1" or 1.1/4" vinyl insert available. As for trim around the windows inside, I am not sure what you have in mind. If you intend to install a trim on the inside as finished framing of the window opening try American Metal Molding at 215-634-3100. They have extensive selection of aluminum trim. If i can be of further assistance PM me. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 02-14-2010, 09:43 AM   #3
1960 24' Tradewind
Riverside , California
http://service.airstream.com/files/l...72b35be844.pdf
This is the trim for a newer trailer, but the panorama windows are the same throughout all years.
Greg
Page I-38
ZoomZoom is offline   Reply With Quote
Argosy Interior Trim caseyd45 All Argosy Trailers 7 01-22-2009 10:38 AM
Interior trim Cochese General Interior Topics 1 06-12-2006 05:39 PM
Removing Interior Aluminum Trim mello mike Cabinets, Counter Tops & Furnishings 9 11-03-2004 05:36 AM
Trim around interior panels Happycampers General Interior Topics 2 09-21-2004 10:38 PM
Interior Trim-Where to find it???? 74Tradewind Upholstery, Blinds, Walls & Interior Finishes 1 07-05-2002 10:12 PM
