Old 04-15-2014, 05:36 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Interior Skin Removal Front
I am getting ready to address some floor rot below the front window and around the door. I will need to remove the interior skins and am wondering if the front window trim needs removed as well. These will be patches and I will not be replacing the entire section but will need to get at the C-channel. Any thoughts? Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
ID:	209724   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 04-15-2014, 05:40 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Indiana, PA
TAC PA-5
WBCCI 4871
Yes,
Colin
Colin H is offline   Reply With Quote
Old 04-15-2014, 06:12 AM   #3
1981 31' Excella II
New Market , Alabama
I am not sure you need to remove the skins to repair such localized damage. However, while you are in there, you can remove the stinky pink stuff and seal the gap in the C-channel and also seal any penetrations through the floor like screw heads etc. The corner rot is from the C-channel gap which you will see once you are in there. I put drains in my C-channel to help prevent floor rot in the event of a leak and there will be a leak event at some point. You need to find the source of the leaks as well. I had some leaks in the window frames from the gasket going bad and several leaks in rivets around the door area.
Yes you need to remove the window frames to get the panels off. I put #8 screws back to hold my panels on, which is probably considered blasphemy around here. They seem to be holding up well. I believe in having access to certain areas for maintenance purposes. I would put rigid foam board insulation back in the walls. While you have the skins off is a good time to look for leaks in a long soaking spring rain.
Perry
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Interior skin removal. 1959 Avion Sprouty Vintage Kin 2 04-07-2013 09:47 AM
Interior Skin Paint Removal Question... sandrad Upholstery, Blinds, Walls & Interior Finishes 2 07-18-2010 08:36 AM
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
