Old 09-22-2006, 10:05 PM   #1
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
Interior skin
Where can I find the interior "skin" or metal used for the interior walls? We are remodeling and I want be using the vent over the old fridge or the furnace and I would like to replace it with something similar, I don't know what to ask for at the hardware store.
cookeville34 is offline   Reply With Quote
Old 09-22-2006, 11:00 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Well, the interior skins of most 70's Airstream are a vinyl clad aluminum, not something you are going to find at your local hardware store. You're probably not going to find vinyl clad aluminum anywhere that matches yours unless you check out some of the RV salvage yards and get lucky.
You could find un-clad aluminum panels though at places like Aircraft Spruce. Then apply a vinyl walcovering, paint, Zolatone of your choice.
Good luck with whatever you decide to do!
Shari
Old 09-23-2006, 07:33 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Another alternative to salvage, is to remove some skin from a concealed location and use it for patching. Then replace it with a different piece. It is my understanding that some sheets of the vinyl coated are still available from some dealers and Airstream, but it is outrageously expensive.
Aaron
WBCCI #XXXX AIR #2495
Old 09-23-2006, 12:29 PM   #4
The original 'ivory" colored vinylcald interior aluminum, has not neen available for some time.
Airstream does however, have a light gray vinylclad available.
Old 09-23-2006, 03:04 PM   #5
1976 26' Argosy 26
St. Albert , Alberta
Vinyl Clad Aluminum?!
Is that same in my '74 Argosy too?! I haven't peeled it back yet, but I had thought for the last two weeks that it was just vinyl. Can someone set me straight 'cause I'm about to clean it off this week.
Thanks!
Chopper is offline   Reply With Quote
Old 09-23-2006, 04:44 PM   #6
Thanks!
All Argosy trailers used "vinylclad" aluminum.
Old 09-25-2006, 03:19 PM   #7
1976 26' Argosy 26
That would explain all the rivets directly in it
Thanks for the glimpse under the skin. That would explain all those rivets in there holding things in place on the interior skin (like the interior divider walls with curved channels). I thought it was the strength of multiple rivets into vinyl or that somehow they were hitting all the frame members!
This also explains the grounding rivets into the interior skin from all those 12V lights!
Thanks for shedding light on this for me!
Cheers!
