Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-30-2003, 09:57 AM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Interior propane lights (lanterns)
I'm curious as to when and why Airstream stopped installing these wall mounted lights. They're downright convenient when boondocking and I like the 'cozy little cabin' ambience they create.
My Caravel has one but if it didn't, I would be shopping for one.
Rog
Rog0525 is offline   Reply With Quote
Old 09-30-2003, 10:37 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I don't think anyone installs them anymore. They are still available. Reasons I can think of: Fire danger, CO danger, propane leak potential, lantern mantle replacement frequency, though they do have ruggedized lantern mantles these days, and heat output during hot summer months.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-30-2003, 02:05 PM   #3
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
lanterns
before i bought my coach... i was biddding on a 1974 rig that had a factory installed propane light (calif)...
although i understand your concerns about carbon mo i thought it would be ideal for the time of year that one would just need a little bit to take the edge off of the dampness in the coach without having to run the furnace.....thats my 2 cents...frugality rules!....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-16-2008, 04:15 PM   #4
1974 27' Overlander
Placerville , California
I know this is an old post but I would like to know what Mantle to use.
ronsgto is offline   Reply With Quote
Old 09-16-2008, 05:25 PM   #5
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Ronsgto,
A regular old Coleman mantle will do in a pinch and in the short term, NOT LONG TERM.
We have many Humphrey propane lanterns in our hunting camp and I believe that is the make that Airstream used to use. The correct mantles are pre-formed and look like this...
Do a google search for Paulin Humphrey and you will find all sorts of information on them.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-16-2008, 10:46 PM   #6
1974 27' Overlander
Thanks much that helps a lot. Looks like some take tie on mantles and some take click on ones like the pic you show. I temporarly tied on a coleman one and it works but not very bright. I think it is a little smal. I will look into getting the right one.
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
