Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-30-2003, 10:57 AM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Interior propane lights (lanterns)
I'm curious as to when and why Airstream stopped installing these wall mounted lights. They're downright convenient when boondocking and I like the 'cozy little cabin' ambience they create.
My Caravel has one but if it didn't, I would be shopping for one.
Rog
Rog0525 is offline   Reply With Quote
Old 09-30-2003, 11:37 AM   #2
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I don't think anyone installs them anymore. They are still available. Reasons I can think of: Fire danger, CO danger, propane leak potential, lantern mantle replacement frequency, though they do have ruggedized lantern mantles these days, and heat output during hot summer months.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 09-30-2003, 03:05 PM   #3
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
lanterns
before i bought my coach... i was biddding on a 1974 rig that had a factory installed propane light (calif)...
although i understand your concerns about carbon mo i thought it would be ideal for the time of year that one would just need a little bit to take the edge off of the dampness in the coach without having to run the furnace.....thats my 2 cents...frugality rules!....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-16-2008, 05:15 PM   #4
Profile:  1974 27' Overlander
Placerville , California
I know this is an old post but I would like to know what Mantle to use.
ronsgto is offline   Reply With Quote
Old 09-16-2008, 06:25 PM   #5
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
Ronsgto,
A regular old Coleman mantle will do in a pinch and in the short term, NOT LONG TERM.
We have many Humphrey propane lanterns in our hunting camp and I believe that is the make that Airstream used to use. The correct mantles are pre-formed and look like this...
Do a google search for Paulin Humphrey and you will find all sorts of information on them.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 09-16-2008, 11:46 PM   #6
Thanks much that helps a lot. Looks like some take tie on mantles and some take click on ones like the pic you show. I temporarly tied on a coleman one and it works but not very bright. I think it is a little smal. I will look into getting the right one.
Running Lights Barkingspider Lights - Interior & Exterior 7 12-11-2003 09:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 03:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 09:55 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 07:43 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 05:51 PM
