Old 01-27-2012, 09:13 AM   #1
1969 21' Globetrotter
Exeter , New Hampshire
Interior Panel order
Hello all,
I recently bought a 21' 69 Globetrotter that was completely gutted when I got it. It came with all of the interior panels in a pile and numbered. I know where they are all suppose to go but do not know the order from where to start. Couple of question:
  • I presume from the bottom up but do you start in the middle, front or back?
  • I'm planning on cleaning with TPS, sand with 150 and prime with kilzs. Should I use latex or oil based
  • Is it easier to prime and paint then re-rivet or rivet and then prime paint
  • Do most people just paint over the rivets?
  • Any other tips or ideas would be great.
Sorry for so many questions but based on reading the forum, I suspect people have some great know how.
Kitter
kitter is offline   Reply With Quote
Old 01-27-2012, 09:47 AM   #2
Central , Mississippi
I just reskinned my Overlander. The original panels made it easy to see the layout, the overlaps didn't have paint so it's possible to spread them out on the ground and decypher the sequence.
I used all new aluminum and in general my sequence was front and rear end caps, sections between the windows, roof, then floor.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-27-2012, 10:11 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
In our '72, the front and rear overhead end caps went on first, then the wall panels below them, followed by the other wall panels, working from the rear forward, bottom to top.
Chris
Old 01-27-2012, 02:31 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
On our trailer, it was easy to tell which order they went in...the Zolatone (paint) gives it away. You can "start somewhere" using clecos to temporarily hold panels in place, then go to the next panel and see if it is over or under (the silver parts go "under") the last one attaching each panel with clecos as you go. Then once you have them all located, start rivetting things back together.
If you don't know what clecos are...check this out - they will become your best friend in skin/panel repair/replacement.
Shari
Old 01-27-2012, 03:00 PM   #5
Originally Posted by kitter View Post
Hello all,
Kitter
The lower panels always are the first to be installed.
Old 01-29-2012, 05:22 PM   #6
On my '91 and my '63, the lower panels were on top of the adjacent ones, indicating they were installed later in the sequence.
Order of Events advice GreyMattr General Repair Forum 6 11-11-2011 10:53 AM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
What is best order. dluker Cleaning, Stripping & Polishing 1 07-28-2011 02:39 PM
Dometic light RM3862 gone, what to order and where? Silver Otter Refrigerators 3 04-24-2011 09:19 PM
replacing tub and sink in order bwaysteve Sinks, Showers & Toilets 8 02-16-2011 07:11 PM
