Old 05-18-2016, 07:45 PM   #15
momof6's Avatar
1976 31' Sovereign
Canton , Georgia
Smile
Originally Posted by Mixter View Post
Momo- nice endcap upgrade. Not to hijack this thread..... but which method did you use for the interior segmented endcap installation? Do you have more pics and details?
Thanks!
Micky
Hi Micky,
Here you go:
http://thesilverrenegade.com/end-cap-from-scratch/
If you have any questions just give me a shout.
Jennifer
momof6 is offline   Reply With Quote
Old 05-19-2016, 12:19 PM   #16
1973 31' Sovereign
saraland , Alabama
This may help,there is a DIY airstream on YouTube and they are fully restoring a 70's airstream trailer. I think episode3-1 is painting the bathroom and 4-1 is painting the walls. It helped me out and he rolled the paint on. I hope this helps you.
just2drive is offline   Reply With Quote
Old 05-19-2016, 06:55 PM   #17
Mixter's Avatar
1976 27' Overlander
Awesome stuff. I spent a little while going through your remodel pics. I'm doing the exact same thing to '76 27 ft Overlander. At about the same stage too. Great job- I'll be watching!
Mic
Mixter is offline   Reply With Quote
Old 05-23-2016, 03:11 PM   #18
1975 Argosy 26
1974 29' Ambassador
1968 20' Globetrotter
Whiterock , British Columbia
Originally Posted by momof6 View Post
Hi Micky,
Here you go:
Jennifer
Hi Jennifer. I had a quick look at your blog. Looks like you are well on the way! The SW primer you used looks like a great product. I used their Corothane-mioaluminum as a primer, but it is an industrial product and not for the faint of heart! It worked great however. Glad to see there is a latex product now available.
I'm curious on the foil insulation you chose. Is it the double layer reflectix? I'm using that on a Wells Cargo trailer that I'm doing for a client, but not sure on R value for use in my current Airstream project. What product are you using, and what is its R value? I'll also second the question on the end caps... Did you use Larry B's technique? That's my plan...
I am the '68 Globetrotter...
redthies is offline   Reply With Quote
Old 05-24-2016, 06:05 AM   #19
momof6's Avatar
1976 31' Sovereign
Canton , Georgia
mixter: Thanks!
redthies: We used one layer of reflective and one layer of recycle jean material.
The reflective is taped on the sides so there air pockets between it and the shell. Then we used 3m spray glue to attach the recycled jean to the reflective. Our R-Value is 13. Our trailer sits directly in the sun here in Georgia and with all the windows open we noticed that the trailer stays cool.
I am not sure who Larry B is here on the Airforum. However, I did read a lot of techniques posted here and pictures on google.
Old 05-28-2016, 08:24 PM   #20
1975 Argosy 26
1974 29' Ambassador
Larry's thread:
http://www.airforums.com/forums/f46/...ed-102982.html
I will look into the denim. I've seen it before but never priced it out. R13 is very good given the space we have to work with. A standard 2x4 wall using fibreglass pink only sees R12.
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
