Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 08-15-2014, 09:17 AM   #1
2014 27' FB International
Port Townsend , 98368
Interior LED LIGHTING
Has anyone found colored LED lights for interior lighting (28' International)? Have you installed them? If not has anyone installed lighting film to provide color/hue tones? Any hints on changing out the bulbs or putting in the colored film? Thanks
NatandGregg is offline   Reply With Quote
Old 08-17-2014, 11:08 PM   #2
triterra's Avatar
1969 27' Overlander
1976 Argosy 28
1978 28' Argosy 28
Lodi , California
I put in RGB LED 16' strip lighting (12V). It has a remote control to change the color, flash, strobe or off. you can cut the strip to any length or run multiple strips together. I have them along the top of the overhead cabinets. I even have a music controller so the lights will flash to the music. You can plug them in or wire them directly into the 12V lighting.
triterra is offline   Reply With Quote
Old 08-18-2014, 11:19 AM   #3
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
