Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 12-24-2015, 07:35 AM   #1
1972 23' Safari
Norwalk , Connecticut
Interior laminates - Intl Models
Wondering if anyone knows what airstream is using for the laminates on the new trailers? Specifically looking at the International Signature Oyster Leather color pallet. Or Possibly the lighter serenity laminate color. My Wife really likes these and we're undergoing a full remodel of our 72. The decision is to follow a decor close to the modern trailers.
When Airsteam says laminate, are they using a formica type material laminated to thin board? Or is it just a thin facing sheet?
Widget is offline   Reply With Quote
Old 12-24-2015, 07:57 AM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Specs for the intl serenity are at bottom of first post here
http://www.airforums.com/forums/show....php?p=1478897
kscherzi is offline   Reply With Quote
Old 12-24-2015, 08:26 AM   #3
1972 23' Safari
Thanks. Glad to know they are using these types of laminates for the cabinet and wall facings. Now I just need to figure out what to use for the actual wall boards which I'll adhere the laminate to.
I've debated building lightweight wood cabinetry, but I think I may attempt to stay in the spirit of the trailer and construct a alu cabinet structure skinned with a laminate sandwich.
I guess I should start a proper thread on the rebuild. It's going to be a long go.
Old 12-24-2015, 11:23 AM   #4
kscherzi's Avatar
Images: 24
Cabinet material in my 2013 is plywood.
Old 12-24-2015, 11:29 AM   #5
1972 23' Safari
Any idea on the thickness?
Old 12-24-2015, 01:51 PM   #6
kscherzi's Avatar
Images: 24
I think it's 1/2 inch. Either 5 or 7 layer. Fairly stable material. I think they use 1 x1's at the joints to use screws to secure to pieces together. Surely someone here, a cabinet maker, can be more specific in regards to materials.
Old 12-25-2015, 11:50 AM   #7
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
There are many, many fine laminates out there, Formica and WilsonArt being two that immediately come to mind. A good store will have samples that you can bring home to try out in place. WilsonArt's glue works quite well, much better than big-box bargain brands.
I would go with 3/4" ply for the countertop surface, and build the rest of the carcass out of 1/4" ply with whitewood stringers around the edges. You can even go nuts like me with super-light Eurolite plywood. The stringers hold screws far better than the edge of plywood.
Something to keep in mind is that when you laminate two sheets of 1/8" ply together, and then torment it into a curve, you have a very strong panel that weighs a fraction of what standard construction does.
We're Airstreamers, we love the curves!
SuzyHomemakr is offline   Reply With Quote
Question on EB laminates jayseejay Eddie Bauer - All Models 4 03-21-2015 12:22 PM
Formica's new laminates unveiled! reinergirl Cabinets, Counter Tops & Furnishings 29 01-26-2015 06:03 PM
Laminates for 2013 International Serenity kscherzi Cabinets, Counter Tops & Furnishings 3 04-04-2014 09:57 PM
Source for laminates for cabinets 2010 sport etobolski Interior Restoration Forum 4 01-06-2014 07:35 PM
Laminates used in 1967 Overlander bighowdytex Cabinets, Counter Tops & Furnishings 11 01-05-2008 07:31 AM
